Calibrating cheap RGB lights using HCFR and Python Scripts
Introduction: Most budget RGB LED lights have terrible factory calibration. Actually they have none. Dim white might be red and higher brightness shoots the colour temperature to the moon! In my case the RGB mode on the light was almost unusable! While Home Assistant allows basic color picking, it doesn’t account for the non-linear behavior of LEDs. This solution uses a 1D LUT (for gray scale/near black) and a 3D Matrix (for primary color correction) to bring professional-grade color management to my “smart” RGB-light.
The idea was to introduce virtual light entity that would control the real light with calibration in between.
  • Hardware: A colorimeter (e.g., i1Display Pro, SpyderX) and the light you wish to calibrate.
  • Software: HCFR Calibration (Free, Windows).
  • Home Assistant Components:
  • HACS: To install the virtual light.
  • Virtual Light Entity: Install this via HACS (GitHub). Add the virtual light as in the guide. Name it “virtual_calibrated_light”
  • Python Script Integration: Add python_script: to your configuration.yaml and restart.
Using colorimeter and HCFR I took:
  • Greyscale measurements in 10 points (10% increment)
  • Primary/Secondary colours (RGBCMY) 25,50,75,100% saturations.
  • Near Black measurements for white (1-4% brightness)
The easiest way to force the light into specific colour was using → Settings → developer tools → actions and command the light from there!
service: light.turn_on
 entity_id: light.ThisLightNeedsCalibration
 rgb_color: [255, 255, 255]
 brightness_pct: 10
 #(increase the brightness as HCFR requests and repeat)
When taking measurements for saturations I used 100% brightness and this table:
|**Colour**|100% Saturation|75% Sat| 50% Saturation | 25% Saturation|
|**Red**|`[255, 0, 0]`|`[255, 64, 64]`|`[255, 127, 127]`|`[255, 191, 191]`|
|**Green**|`[0, 255, 0]`|`[64, 255, 64]`|`[127, 255, 127]`|`[191, 255, 191]`|
|**Blue**|`[0, 0, 255]`|`[64, 64, 255]`|`[127, 127, 255]`|`[191, 191, 255]`|
Export the measurements to excel.
For Saturations I had to manually copy/paste the values from HCFR because the export function is limited and only exports Greyscale or Primary values. No saturations or other measurements.
Fortunately you can just drag your mouse over the table and Ctrl-C - Ctrl-V them to excel!
When the data from the light was in the excel I asked AI to generate me the calibration from that data!
This is what it came up with.
  • Add this to home_assistant/python_scripts/calibrate_light.py
Home Assistant Python Script: Advanced RGB Light Calibration
Author: Juza89
Description: Applies 1D LUT (gamma/white balance) and 3D Matrix correction
based on HCFR measurements.
# 1. INPUT DATA
# These are passed from the automation trigger
entity_id = data.get("entity_id")
rgb_in = data.get("rgb_color", [255, 255, 255])
brightness = data.get("brightness", 255)
# 2. CALIBRATION DATA (Replace with your own HCFR results)
# Brightness percentage points (X-axis of your LUT)
pts = [0, 5, 10, 20, 30, 40, 50, 60, 70, 80, 90, 100]
# 1D LUT: RGB correction factors for each point in 'pts'
# Derived from your Gray Scale and Near Black measurements
r_lut = [0.0, 0.45, 0.58, 0.65, 0.72, 0.78, 0.82, 0.85, 0.88, 0.92, 0.96, 1.0]
g_lut = [0.0, 0.80, 0.95, 1.00, 1.00, 1.00, 1.00, 1.00, 1.00, 1.00, 1.00, 1.00]
b_lut = [0.0, 0.22, 0.30, 0.38, 0.45, 0.50, 0.54, 0.58, 0.62, 0.65, 0.68, 0.70]
# COLOR MATRIX: Cleans up crosstalk between LED channels
# Calculated from Primary (R,G,B) and Secondary (C,M,Y) measurements
matrix_r = {"r": 1.15, "g": -0.12, "b": -0.03}
matrix_g = {"r": -0.05, "g": 1.25, "b": -0.20}
matrix_b = {"r": -0.02, "g": -0.08, "b": 1.10}
# Perceived contrast adjustment
gamma_value = 2.1
# 3. CALCULATIONS
def interpolate(val_pct, lut):
    """Calculates a smooth transition between two measurement points."""
    for i in range(len(pts) - 1):
        if pts[i] <= val_pct <= pts[i+1]:
            return lut[i] + (val_pct - pts[i]) * (lut[i+1] - lut[i]) / (pts[i+1] - pts[i])
    return lut[-1]
def clamp(v):
    """Keeps RGB values within the valid 0-255 range."""
    return max(0, min(255, int(v)))
# Get current scaling from LUT
target_pct = (brightness / 255) * 100
r_scale = interpolate(target_pct, r_lut)
g_scale = interpolate(target_pct, g_lut)
b_scale = interpolate(target_pct, b_lut)
r_raw, g_raw, b_raw = rgb_in[0], rgb_in[1], rgb_in[2]
# Apply 3D Matrix transformation to clean primary colors
r_mat = (r_raw * matrix_r["r"]) + (g_raw * matrix_r["g"]) + (b_raw * matrix_r["b"])
g_mat = (r_raw * matrix_g["r"]) + (g_raw * matrix_g["g"]) + (b_raw * matrix_g["b"])
b_mat = (r_raw * matrix_b["r"]) + (g_raw * matrix_b["g"]) + (b_raw * matrix_b["b"])
# Apply Gamma and Scale
r_final = ((max(0, r_mat) / 255) ** gamma_value) * 255 * r_scale
g_final = ((max(0, g_mat) / 255) ** gamma_value) * 255 * g_scale
b_final = ((max(0, b_mat) / 255) ** gamma_value) * 255 * b_scale
# White Point Bypass: Maintain neutral white when R=G=B=255
if r_raw == 255 and g_raw == 255 and b_raw == 255:
    r_out, g_out, b_out = 255 * r_scale, 255 * g_scale, 255 * b_scale
else:
    r_out, g_out, b_out = r_final, g_final, b_final
# 4. CALL PHYSICAL SERVICE
service_data = {
    "entity_id": entity_id,
    "rgb_color": [clamp(r_out), clamp(g_out), clamp(b_out)],
    "brightness": brightness
hass.services.call("light", "turn_on", service_data)
After the python script is added we need to add the automation that calls this script!
Settings → Automations → Create new automation → edit in yaml.
alias: Virtual → Real (Python Calibrated)
description: ""
triggers:
  - entity_id: light.virtual_calibrated_light
    trigger: state
actions:
  - choose:
      - conditions:
          - condition: state
            state: "off"
        sequence:
          - action: light.turn_off
      - conditions: []
        sequence:
          - action: python_script.calibrate_light
              rgb_color: >-
                {{ trigger.to_state.attributes.rgb_color |
                default([255,255,255]) }}
              brightness: "{{ trigger.to_state.attributes.brightness | default(255) }}"
Even without access to colorimeter anyone could take this code and adjust those factors manually to have some calibration to these cheap rgb lights or strips! I’m posting this because I could not find this sort of advanced calibration solution anywhere and hope this could help someone!
This is the result for the greyscale after I tweaked the numbers a bit.
#         0      5    10    20    30    40    50    60    70    80    90  100
r_lut = [0.12, 0.13, 0.43, 0.50, 0.47, 0.61, 0.63, 0.68, 0.70, 0.70, 0.73, 0.87]
g_lut = [0.25, 0.25, 0.83, 0.88, 0.80, 0.97, 0.96, 0.95, 0.93, 0.92, 0.89, 1.00]
b_lut = [0.15, 0.15, 0.58, 0.56, 0.50, 0.59, 0.58, 0.58, 0.55, 0.54, 0.53, 0.60]
Because from previous picture we see that the brightness plateous at 70% (Y-value) and brightness slider is not as precise as I would like, lets introduce gamma correction for brightness and upper limit to 70%. Because the Gamma function can output values too low for the LED driver to handle at low levels, we’ll also introduce a “min_brightness” floor to keep the LEDs from turning off at too low levels.
Updated Code
Home Assistant Python Script: Advanced RGB Light Calibration v5.0
Author: Juza89
Features:  & 1D/3D Color Correction
Description: Gamma Brightness Remapping with 1D LUT (gamma/white balance) and 3D Matrix correction
# 1. INPUT DATA
brightness_in = data.get("brightness", 255)
# 2.BRIGHTNESS CALIBRATION VARIABLES
upper_limit = 0.70
min_brightness = 0.01 # 4% is usually enough to keep most LEDs on. Adjust if needed.
# Perceived brightness gamma (1.0 is linear, 2.0-2.5 is more natural)
brightness_gamma = 1.7
# Color Correction LUT (Your measured points)
# Color Correction Matrix
# Internal Color Gamma (for color saturations)
color_gamma = 2.1
# 3. CALCULATIONS
    return lut[-1]
# A. MATHEMATICAL BRIGHTNESS REMAPPING
slider_norm = brightness_in / 255.0
if slider_norm <= 0:
    physical_norm = 0
else:
    # Calculate the gamma curve
    gamma_remap = slider_norm ** brightness_gamma
    # Scale the gamma curve so it starts at 'min_brightness'
    # and ends at 'upper_limit'
    physical_norm = min_brightness + (gamma_remap * (upper_limit - min_brightness))
# Convert to 0-255 for the physical light and 0-100 for the LUT
physical_brightness = physical_norm * 255
physical_pct = physical_norm * 100
# B. COLOR SCALING (Based on the new calculated physical level)
r_scale = interpolate(physical_pct, r_lut)
g_scale = interpolate(physical_pct, g_lut)
b_scale = interpolate(physical_pct, b_lut)
# C. MATRIX & COLOR GAMMA
r_f = ((max(0, r_mat) / 255) ** color_gamma) * 255 * r_scale
g_f = ((max(0, g_mat) / 255) ** color_gamma) * 255 * g_scale
b_f = ((max(0, b_mat) / 255) ** color_gamma) * 255 * b_scale
else:
    r_out, g_out, b_out = r_f, g_f, b_f
# 4. EXECUTE
hass.services.call("light", "turn_on", {
    "rgb_color": [max(0, min(255, int(r_out))), max(0, min(255, int(g_out))), max(0, min(255, int(b_out)))],
    "brightness": max(0, min(255, int(physical_brightness)))
More advanced calibration method with automated measurements using DisplayCAL and 3DLut calibration can be found here
