I noticed that my Nous Zigbee sockets unfortunately do not show the exact current values. The values of the formula amps = watts / volts do not give the correct values. As an example, the following values (28 watts, 232 volts) output 0.2 amps. Is there a way to perform a calibration in zha?
Hi have the same issue, a solution would be great. Is there a way to calibrate the smart plug via ZHA?
