Caling script with parameter (a timer)
I have a lot of timers that I use in my kitchen, I would like to prevent a timer from restarting if you click on it while it is in use, here is my idea of a script, what is wrong
alias: timertest
sequence:
  - if:
      - condition: template
        value_template: "{{ state(\"thetimer\",\"Idle\") }}"
    then:
      - service: timer.start
        data: {}
          entity_id: "{{ thetimer }}"
mode: single
I am missing the part where you call the script. The call should contain the variable that holds the actual timer entity_id.
One can do in several ways:
service: script.timer
  thetimer: "timer_entity_id"
service: script.turn_on
  entity_id: script.timer
  variables:
The service call when tabbing the time should trigger the script
