Call a service dependant on drop down value
I have a helper configured like this:
I can show this as an entity in Lovelace, but I am unsure how to call a service depending on the state of this - i’m not great with scripts etc.
Basically, if the state is changed, it needs to call a service where one of the attributes is the state
You have an example in the input_select doc:
 # This automation script runs when the thermostat mode selector is changed.
 # It publishes its value to the same MQTT topic it is also subscribed to.
- alias: "Set Thermostat Mode"
    platform: state
    entity_id: input_select.thermostat_mode
    service: mqtt.publish
      topic: "thermostatMode"
      retain: true
      payload: "{{ states('input_select.thermostat_mode') }}"
That doesnt seem to work for me:
  "action":
      service: surepetcare.set_lock_state
         flap_id: '680285'
         lock_state: '{{ states(''input_select.flap_state.state'') }}'
gives me an error:
 Stopped because an error was encountered at 16 August 2021, 11:23:04 (runtime: 0.02 seconds)
value must be one of ['locked_all', 'locked_in', 'locked_out', 'unlocked'] for dictionary value @ data['lock_state']
states(''input_select.flap_state'')
Genius! Thank you. Today I have learnt something, appreciate the help. :slight_smile:
