Call action in Blueprint only if bool = off
I’m writing my first blueprint. In the “action” part I have one action which is called every the blueprint triggers and one action which will be called only if the variable “device_boolean” is off.
blueprint:
  description: Switch on an input_boolean when consumption goes up
  domain: automation
  input:
    power_sensor:
      description: Power sensor entity (e.g. from a smart plug device).
      selector:
        entity:
          domain: sensor
    consumption_limit:
      description: Power threshold above which we assume the appliance has started.
      default: 10
      selector:
        number:
          min: 1.0
          max: 100.0
          unit_of_measurement: W
          mode: slider
          step: 1.0
    starting_hysteresis:
      name: Time duration switching on
      description: Time duration the power measurement has to stay above the starting
        power threshold.
      default: 0
      selector:
        number:
          min: 0
          max: 180
          unit_of_measurement: sec
          mode: slider
          step: 1
    finishing_hysteresis:
      name: Time duration switching off
      description: Time duration the power measurement has to stay below the finishing
        power threshold.
      default: 0
      selector:
        number:
          min: 0
          max: 180
          mode: slider
          step: 1
    device_boolean:
      description: Helper variable
      selector:
        entity:
    actions:
      description: Actions (e.g. pushing a notification, TTS announcement, ...)
      default:
      selector:
        action: {}
  source_url: https://gist.github.com/xxx
variables:
  device_boolean: !input 'device_boolean'
- platform: numeric_state
  entity_id: !input 'power_sensor'
  for:
    seconds: !input 'starting_hysteresis'
  above: !input 'consumption_limit'
  for:
    seconds: !input 'finishing_hysteresis'
  below: !input 'consumption_limit'
condition: []
  - service: >
      {% if trigger.above %}
        input_boolean.turn_on
      {% else %}
        input_boolean.turn_off
      {% endif %}
    data: {}
    entity_id: !input 'device_boolean'
  - choose:
      - conditions:
          - condition: template
              value_template: '{{ device_boolean.state  == "off" }}'
        sequence: !input 'actions'
    default: []
mode: single
max_exceeded: silent
In the logs I find an error:
 Logger: homeassistant.config
Source: components/blueprint/models.py:259
First occurred: 1:47:35 AM (9 occurrences)
Last logged: 1:52:50 AM
Invalid config for [automation]: Failed to load blueprint: Unable to find _caspar/consumption-switcher.yaml (See /config/configuration.yaml, line 5).
But unfortunately, I don’t know what is wrong.
Can someone help me?
That would be really great, becaus I’m working on it since hours, without a solution.
Thank you
Cas
I found a solution. Check this out:
blueprint:
  domain: automation
  input:
    power_sensor:
      selector:
        entity:
          domain: sensor
    consumption_limit:
      default: 10
      selector:
        number:
          min: 1.0
          max: 100.0
          mode: slider
          step: 1.0
        power threshold.
      default: 0
      selector:
        number:
          min: 0
          max: 180
          mode: slider
          step: 1
        power threshold.
      default: 0
      selector:
        number:
          min: 0
          max: 180
          mode: slider
          step: 1
    device_boolean:
      selector:
        entity:
    actions_on:
      default:
      selector:
        action: {}
    actions_off:
      default:
      selector:
        action: {}
variables:
  for:
  for:
condition: []
- service: >
    {% else %}
    {% endif %}
  data: {}
- choose:
    - conditions:
        - condition: state
          state: "on"
      sequence: !input 'actions_on'
- choose:
    - conditions:
        - condition: state
          state: "off"
      sequence: !input 'actions_off'
mode: single
