Call async function from sync function
Hello! I’m trying to implement some integration for my covers. I’m using DataUpdateCoordinator , because with one call to API, I can obtain states for all my covers. But in some cases, I need to call another API method (sometimes my covers can ignore the first request and forget to close, for example, so I have to send close request again). Unfortunately I cannot call async method (fetch) which is provided by API from sync method (_handle_coordinator_update) which is called by CoordinatorEntity after fetching current state for cover.
BTW, is it fine to call time-consuming request to external and probably slow server in _handle_coordinator_update? I know that for example, calling time-consuming method from current_cover_position is not good idea. I’m wondering _handle_coordinator_update is also not good place for that methods.
class HelloBlind(CoordinatorEntity, CoverEntity):
    # Some code...
    @callback
    def _handle_coordinator_update(self) -> None:
        # Trying to call: self._do_something_specific()
        return super()._handle_coordinator_update()
    async def _do_something_specific(self) -> None:
        await self._api.fetch('XXX')
Yep, you can do: Working with Async | Home Assistant Developer Docs
