Call different Service based on a condition
I am trying to call a different service based on a variable (y variable in Honeycomb menu). If positive call Service “A”, else call Service “B”.
Any advice on how to do this?
Thank You
actions:
  - action: "{{ 'service A' if VARIABLE else 'service B' }}"
Would be clearer if you provide the service names, what the variable is, and where you’re calling this (script, automation, something else?).
You’ve tagged the topic “front-end” — was that intentional?
I am trying like you suggest but no success till now.
Here the snippet of code of the honeycomb menu:
tap_action:
  action: call-service
  service: honeycomb
  service_data:
    xy_pad:
      y:
        actions:
          action: "{{ if y > 0 'cover.open_cover' else 'cover.close_cover' }}"
          service_data:
          entity_id: cover.mycover
Thank You
Bottom of the Actions documentation:
It is not possible to use templates for actions. But calling a script is a good alternative.
Ok I can try with scripts.
So I have to call this new script from the action in my main code?
And how do I pass to the script the y variable?
Regards
This looks like it might help. If this is what you are using, there seems to be a small amount of templating available in the xy_pad, but I have no expereince of working with this:
