Call 'reconfigure device' programmatically
I have to situations where I was to reconfigure a device programmatically.
One is a lightbulb that misbehaves (stops obeying it’s bound switch) and then fixes itself when reconfigured.
The second is a battery powered device in an inaccessible place that I accidentally unbound from the co-ordinator but does send ‘checkin’ requests - so I want to send a re-configure request when I know its awake (when it checks in)
Is there a service call in ZHA to call the ‘reconfigure device’ option?
If so I could build an automation to do this for me.
I’m looking for this feature too!!! I hope someone help us!!! Sometimes I’ve a bulb doesn’t works and I need to reconfigure it in order to power off. If I had this command I could do an automation.
…same here … any updates?
Here as well on a Nodon sunscreen controller. Works brilliantly for a few months, but gets confused after not being used for a while. Reconfigure fixes itself and works like a charm. Just want to send a reconfigure as a monthly reset command at midnight.
Any word on this? Need it, too.
Same problem here. +1
Maybe using the zha toolkit rejoin command?
Added to feature discussion in HA repo: ZHA device "reconfigure" exposed as HA developer action · home-assistant · Discussion #2868 · GitHub
Upvote!
