Select Domain > homeassistant
Select Serve > restart
Press CALL SERVICE button
Bottom message says failed to call service homeassistant/restart
Is it just my set up or is anybody else seeing this?
Re Dave
Re Dave
I’m seeing the same issue - the message is popping up but the restart doesn’t actually happen.
Release Notes:
This is more than a little confusing.
If it checks the config and there is an error in it that prevents a proper restart then a message should come up to tell me that.
When I restart from the command line HASS starts fine - so the config cannot be that wrong.
The error message I see in the dev-info is actually:
17-02-11 18:19:39 ERROR (MainThread) [homeassistant.loader] Unable to find component Configuration
Maybe that has to do with the issue I’m seeing when I try to verify my config with the command ‘hass --script check_config’:
-bash: hass: command not found
Ay insights?
Running HA .38.0 on synology 916+ via docker. I’m getting the following log error, when attempting to use the restart service however it does say restart service was called:
ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved Traceback (most recent call last): File "uvloop/future.pyx", line 372, in uvloop.loop.BaseTask._fast_step (uvloop/loop.c:112669) File "/usr/src/app/homeassistant/core.py", line 1018, in _event_to_service_call yield from service_handler.func(service_call) File "/usr/src/app/homeassistant/components/__init__.py", line 159, in async_handle_core_service yield from conf_util.async_check_ha_config_file(hass) File "/usr/src/app/homeassistant/config.py", line 472, in async_check_ha_config_file stdout=asyncio.subprocess.PIPE) File "/usr/local/lib/python3.5/asyncio/subprocess.py", line 212, in create_subprocess_exec stderr=stderr, **kwds) File "uvloop/loop.pyx", line 2164, in __subprocess_run (uvloop/loop.c:39415) File "uvloop/handles/process.pyx", line 549, in uvloop.loop.UVProcessTransport.new (uvloop/loop.c:93764) File "uvloop/handles/process.pyx", line 87, in uvloop.loop.UVProcess._init (uvloop/loop.c:85151) PermissionError: [Errno 13] Permission denied
Hi
FYI mine is with a virgin config file, just using the new hassbian toybox image.
I have not changed anything in my configuration file.
Re Dave
I have just updated my good version of HA, i.e. this has been running fine for 1 week, no errors in config.
The Restart also now does not work on 0.38.1.
Is everybody else not having this issue?
Regards, Dave
Same here. It gives a fail but does restart.
same here.
I am running the latest version and even the config has no error but still restart getting failed.
im seeing the same thing on 38.3, failed restart message with no restart. I have to reboot my Pi to update my config.
About the same here @38.2… Message stating restart failed but it does restart though.
When there is na actual config error restart fails and it shows an error in the frontend as expected.
I am finding that it does actually restart, even though the message sates otherwise
Re Dave
