Hi!
I’m new to Home Assistant, so possibly what I’m trying to do is trivial but I can’t get it to work and can’t find any example of something similar.
I’m trying to call a script from an automation and passing a variable “position” that will be used in two script actions (one is a condition and other is to set a device position).
I’m able to call the service from the automation without variables, but when adding the variable I can’t get it to work.
For my automation I have the following code:
alias: LowerBlinds
description: ''
- platform: time
at: '18:00'
condition: []
- service: script.setblinds
position: 10
mode: single
Now in the Script I want to use the value of the variable “position” (10) so I’m writing it this way:
alias: SetBlinds
fields:
position:
description: 'The position for blind'
example: '25'
sequence:
- condition: numeric_state
entity_id: cover.ecozinha
attribute: current_position
above: {{ position }}
- device_id: 2812797da98b437f32d90e2ccb79144e
domain: cover
type: set_position
position: {{ position }}
mode: single
When saving I get the following error:
Message malformed: expected float for dictionary value @ data[‘sequence’][0][‘above’]
I already tried several different ways according to the documentation and examples I found, also tried to use the generic “script.turn_on” service but can’t get it to work.
Thanks!
Hi! Thank you for your suggestion.
Sorry for not have mentioned before, I also tried that way, and get the same error.
Why cant you use an input_text instead of this variable? It would give more control and this automation can be easily done.
@Burningstone thanks for the suggestion, I tried this way:
alias: SetBlinds
sequence:
above: "{{ position | float }}"
domain: cover
type: set_position
position: "{{ position | float }}"
mode: single
fields:
position:
description: The position for blind
example: '25'
…but unfortunately I got the same error
@sheminasalam not sure what you mean by using an input_text. I’m calling the script from an automation, how should I do it with an input_text, can you share some example?
Thanks!
What i meant was that you can store the value of position in an input_text entity. By this way you will be able to change the position to any value just by changing using the sericve input_text.set_value. And in your script instead of using the variable “position”, you can call the state of this input_text to get the position.
@sheminasalam thanks for your suggestion, sounds like an option to solve my problem.
So, here is what I have done so far:
Created a new input_text variable called “input_text.eescrit_25” and set value to 10.
Changed my automation, as now I have the value in the input_text I don’t need to send it when calling the script as a service:
alias: LowerBlinds
description: ''
- platform: time
at: '18:00'
condition: []
mode: single
Changed the script to get the value from input_text:
alias: SetBlinds
sequence:
above: '{{ input_text.eescrit_25.value }}'
domain: cover
type: set_position
position: '{{ input_text.eescrit_25.value }}'
mode: single
I still get the same error, possibly I’m missing something. Is this the correct way to get the value of the input_text?
I tried:
'{{ input_text.eescrit_25.value | float }}'
'{{ input_text.eescrit_25 }}'
But non of them works.
Try this for your script.
alias: SetBlinds
sequence:
- condition: template
value_template: >-
{{state_attr('cover.ecozinha', 'current_position') | int >=
states('input_text.eescrit_25') | int }}
- service: cover.set_cover_position
position: '{{states(''input_text.eescrit_25'') | int }}'
mode: single
Also instead on input_text you can look into input_number which will give you a slider too.
@sheminasalam thanks a lot for the suggestion, that works!
Ok, I think the problem is that you can’t template above/below in the condition.
@sheminasalam’s workaround certainly works, but it’s not scalable when you use this in multiple places and defeats the purpose of the script called conpletely.
Changing the condition to a template condition should work and not require an intermediate input_text (also because it’s a number an input_number qould make more sense in this case).
alias: SetBlinds
sequence:
value_template: >
{{state_attr('cover.ecozinha', 'current_position') | int >= position }}
position: '{{ position | int }}'
@Burningstone absolutely, also tested your suggestion, this way I can reuse the script for any required position.
I can even pass the entity id I want to affect as another parameter, so the script become more generic.
Thank you all for the help and suggestions! I’m still starting to learn how HA works
