outrun
(Lukas Ecklmayr)
December 13, 2016, 7:03pm
1
He Guys,
One question:
If i run these on my HA my Denon Receiver changes its input correctly:
In my automation, this doesn’t work
- alias: Fernsehen
platform: state
entity_id: input_select.fernbedinung
to: "Fernsehen"
- service: script.vierapoweron
- service: media_player.turn_on
entity_id: media_player.denon
- service: media_player.select_source
source: TV Audio
- delay: '00:00:10'
- service: script.vierafernsehen
Anyone can guess why?
ih8gates
(Scott Reston)
December 13, 2016, 7:32pm
2
Could it be that you need a bit of time after turning on the device before it’ll accept commands?
(aside - I can’t remember… can you use delays in actions or only in scripts? Also, I’m not 100% sure you’ve got the format for delay correct. )
outrun
(Lukas Ecklmayr)
December 13, 2016, 7:49pm
3
He @ih8gates thanks for Input. I’ll give it a try after my wife is finished with watching tv. Delay is working in automation and syntax should be correct. I’m using it in another automation.
BR
outrun
(Lukas Ecklmayr)
December 13, 2016, 8:36pm
4
Got it to work. Have to put TV AUDIO under “”.
Here the working Code:
- alias: Fernsehen
platform: state
to: "Fernsehen"
source: "TV AUDIO"
- delay: '00:00:10'
ih8gates
(Scott Reston)
December 13, 2016, 9:01pm
5
That likely raised an error in your home_assistant.log. Always check there first when things act up.
@outrun Thanks so much for this piece of code - I now have a script running to get everything setup for when I go out to swim in the backyard - turns on zone 2 and sets source appropriately. Much appreciated!!
