Bringing back old topic - same debugging. Feel like I am missing something simple, like a space… ugh
when I put this into developer tools, services - I get the notification. as expected:
"title":"test",
"message":"message",
"data":{ "sound":"US-EN-Alexa-Garage-Door-Opened.wav" }
However, in node red, I get API error with following payload in a function node (trying to build out a template for dynamic use)
var payload = {"title":"test","message":"message","data":{ "sound":"US-EN-Alexa-Garage-Door-Opened.wav" }}
msg.payload = payload
return msg
flow:
[{"id":"3b0f5d3f.da4942","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"b2174036.73bfb","type":"inject","z":"3b0f5d3f.da4942","name":"","topic":"","payload":"test","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":110,"y":100,"wires":[["59e9e428.2351dc"]]},{"id":"f8401ce2.b84a7","type":"api-call-service","z":"3b0f5d3f.da4942","name":"test IOS","server":"2a12269e.94634a","version":1,"debugenabled":false,"service_domain":"notify","service":"mobile_app_paul_xs","entityId":"","data":"{{msg.payload}}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":620,"y":100,"wires":[[]]},{"id":"59e9e428.2351dc","type":"function","z":"3b0f5d3f.da4942","name":"Create Alexa Alert","func":"var name = \"IOS Alert Template: \"\n\nvar message1 = \"Beging message here \" \nvar message2 = flow.get('friendly_name') \nvar message3 = \"End of message here\"\nvar sound = \"US-EN-Alexa-Garage-Door-Opened.wav\"\n\n\nvar final_msg = `${message1}` + `${message2}` + `${message3}`\nvar payload = {\n \"title\":\"test\",\"message\":\"message\",\"data\":{ \"sound\":\"US-EN-Alexa-Garage-Door-Opened.wav\" }\n \n}\nmsg.payload = payload\nreturn msg","outputs":1,"noerr":0,"x":330,"y":100,"wires":[["f8401ce2.b84a7","5aa00df6.b8abd4"]]},{"id":"5aa00df6.b8abd4","type":"debug","z":"3b0f5d3f.da4942","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":530,"y":160,"wires":[]},{"id":"2a12269e.94634a","type":"server","z":"","name":"Home Assistant1","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true}]
