"Call-service API error. Error Message: Service not found."
Newbie to Node-Red and to hass.
I try to trigger lights based on motion from a binary sensor and condition that I’m not on holiday (semester) and that it’s nighttime (Natt). I have a hassio image and have installed Node-Red from Add-on store.
Everything seems to work until the last node. I use “Call service node”. I get this error message: “Call-service API error. Error Message: Service not found.”
Flow
Was only allowed one image so skip this for now.
Node config
Debugg
Any help appreciated!
Ok, so I played around some more and tested with another domain (used switch and light before) , first with input_boolean and then with homeassistant. With homeassistant the flow worked and I would really like to know why…
Btw. your picture helped me, I was strugelling a lot…Thanks.
finally did you resolve api error?
Yes, the domain should have been “switch” not homeasstitant
