I’d like to make an Alert that plays a message on my smart speaker. Is that possible? The way I play messages from Automations is by using Call service → RESTful Command as action
, but that doesn’t seem to be an option when using an Alert?
The Alert integration is really well documented. With which configuration step do you have problems?
You can do a workaround by setting up an Alert using an empty notifier and automation based on an Event trigger
I just saw that I can turn an HTTP call into a notifier with the RESTful Notifications integration. I should then be able to use the notifier in an Alert.
