Eduard76
(Eduard)
August 1, 2021, 11:05am
1
HI there,
HA newbie here!
I’m trying to control my philips tv on/off setting with HA. I have now managed to create an “on” switch with a WOL config. Now, I am trying to configure the “turn_off” part of the switch.
My TV has an option for turning off from HA, by using a service call.
This works fine as automation, but when I add this to the switches.yaml like so:
- platform: wake_on_lan
mac: "xx-xx-xx-xx-xx-xx"
host: 192.168.x.x
turn_off:
service: media_player.turn_off
entity_id: media_player.55pus6804_12
My config is deemed incorrect:
Invalid config for [switch.wake_on_lan]: [service] is an invalid option for [switch.wake_on_lan]. Check: switch.wake_on_lan->service. (See ?, line ?)
I’ve tried moving the turn off commands into a script and calling the script, but as you’re also calling a service to call a script, this also fails.
Any ideas how to do this?
Kind Regards,
Eduard
koying
(Chris B)
August 1, 2021, 11:15am
2
Your indentation is wrong. Try:
host: 192.168.x.x
turn_off:
Eduard76
(Eduard)
August 3, 2021, 8:47am
3
Yes! This works!
Still sometimes forgetting the indentations; I mostly assume that when visual studio code doesn’t complain it’s OK, but apparently not
Thank you!
koying
(Chris B)
August 3, 2021, 9:06am
4
If you install the Home Assistant extension and set the file format to “Home Assistant”, it will complain…
DuFu
August 30, 2023, 1:51pm
5
Doesn’t work for me.
Switch was created, but Turn Off part does not switch off TV, only wakeup (WOL) works.
mac: "XX:XX:XX:XX:XX:XX"
host: "COM-MID1"
turn_off:
service: remote.turn_off
entity_id: remote.65ez1000_series
While this automation works fine
alias: Turn Off TV
description: ""
- device_id: 07bfe92a154711ee022e23e2647b7e93
domain: zha
platform: device
type: remote_button_short_press
subtype: turn_off
condition:
- condition: state
state: "on"
- service: remote.turn_off
data: {}
entity_id:
- remote.65ez1000_series
mode: single
PS I tried media_player.turn_off
service. Doesn’t work also, while similar automation works fine.
