I am learning about Trigger IDs, so I set up an automation to turn on/off the Guest Bedroom light based on motion detection. The automation works but I had to select the specific light switch via “devices”.
I am learning that the best practice is to use “Call Service” and select your device. However, when I tried to use the Call Service in the action area, all areas in my home show - EXCEPT the Guest Bedroom.
I confirmed the area is shown in Zones/Areas, the light switch and the motion sensor are assigned to the Guest Bedroom.
So - why does it not show in the “Call Service: Light: Turn On” function…or the Choose area or device or entity?
@Dujith Yup - just learned… switches and lights are different. Understand about the reboot - I do a restart, if that does not work I do a reboot…on some other issues the reboot solves the problem.
However - I appreciate the help !! Learning something new every day…
Please consider marking my post above with the Solution tag. It will automatically place a check-mark next to the topic’s title which signals to other users that this topic has been resolved. This helps users find answers to similar questions.
