PART 1 of 2
[{"id":"5f403e00.def6","type":"tab","label":"Hallway Auto","disabled":false,"info":""},{"id":"e2602f6f.1f27b","type":"server-state-changed","z":"5f403e00.def6","name":"Hallway precence","server":"2f469d31.dfdb72","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_boolean.hallway_precense_switch","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":110,"y":740,"wires":[["f99d82b9.327b3"]]},{"id":"4166d62.6641aa8","type":"switch","z":"5f403e00.def6","name":"Av eller på","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":470,"y":420,"wires":[["9ed37c.80b76c88"],["33a0928e.7d0036"]]},{"id":"33a0928e.7d0036","type":"api-call-service","z":"5f403e00.def6","name":"Hallway off","server":"2f469d31.dfdb72","version":1,"debugenabled":false,"service_domain":"scene","service":"turn_on","entityId":"scene.hallway_off","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":750,"y":460,"wires":[[]]},{"id":"9ed37c.80b76c88","type":"api-call-service","z":"5f403e00.def6","name":"Hallway on","server":"2f469d31.dfdb72","version":1,"debugenabled":true,"service_domain":"scene","service":"turn_on","entityId":"scene.hallway_on","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":750,"y":360,"wires":[[]]},{"id":"de51b883.d47a38","type":"api-call-service","z":"5f403e00.def6","name":"","server":"2f469d31.dfdb72","version":1,"debugenabled":false,"service_domain":"input_boolean","service":"turn_on","entityId":"input_boolean.hallway_precense_switch","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":960,"y":140,"wires":[[]]},{"id":"aa1d3154.aa76a","type":"server-state-changed","z":"5f403e00.def6","name":"Hallway Motion","server":"2f469d31.dfdb72","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.hallway_motion_detector_sm_gang_motion","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":140,"y":120,"wires":[["b95528e7.1902e8","c0ca5e78.b4ce58"]]},{"id":"39993977.03d656","type":"server-state-changed","z":"5f403e00.def6","name":"","server":"2f469d31.dfdb72","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.hallway_motion_detector_ut_motion","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":300,"y":160,"wires":[["b95528e7.1902e8","c0ca5e78.b4ce58"]]},{"id":"75841de9.18e67c","type":"server-state-changed","z":"5f403e00.def6","name":"","server":"2f469d31.dfdb72","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.hallway_motion_sensor_motion","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":280,"y":200,"wires":[["b95528e7.1902e8","c0ca5e78.b4ce58"]]},{"id":"74af881e.3ce3e","type":"server-state-changed","z":"5f403e00.def6","name":"","server":"2f469d31.dfdb72","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.hallway_motion_sensor_sov_motion","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":300,"y":240,"wires":[["b95528e7.1902e8","c0ca5e78.b4ce58"]]},{"id":"b95528e7.1902e8","type":"switch","z":"5f403e00.def6","name":"Av eller på","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":710,"y":160,"wires":[["de51b883.d47a38","2ba09064.7c36c8"],["2ba09064.7c36c8"]]},{"id":"c0ca5e78.b4ce58","type":"debug","z":"5f403e00.def6","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":690,"y":60,"wires":[]},{"id":"fd681e3a.e807e","type":"api-call-service","z":"5f403e00.def6","name":"","server":"2f469d31.dfdb72","version":1,"debugenabled":false,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.hallway_precense_switch","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":960,"y":200,"wires":[[]]},{"id":"2ba09064.7c36c8","type":"trigger","z":"5f403e00.def6","name":"","op1":"","op2":"off","op1type":"nul","op2type":"str","duration":"2","extend":false,"overrideDelay":false,"units":"min","reset":"on","bytopic":"all","topic":"topic","outputs":1,"x":770,"y":300,"wires":[["fd681e3a.e807e"]]},{"id":"f99d82b9.327b3","type":"switch","z":"5f403e00.def6","name":"Av eller på","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":290,"y":1140,"wires":[["6c6b14e2.33d194"],["feaf93cf.6ac408"]]},{"id":"eefef968.c1a9b","type":"switch","z":"5f403e00.def6","name":"MODUS SWITCH","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Morning","vt":"str"},{"t":"eq","v":"Day","vt":"str"},{"t":"eq","v":"Evening","vt":"str"},{"t":"eq","v":"Night","vt":"str"},{"t":"eq","v":"DeepNight","vt":"str"},{"t":"eq","v":"Away","vt":"str"},{"t":"eq","v":"MovieTime","vt":"str"},{"t":"eq","v":"Alarm","vt":"str"},{"t":"eq","v":"Clean","vt":"str"}],"checkall":"true","repair":false,"outputs":9,"x":830,"y":860,"wires":[["1e9d502.6aad0b","67e15122.f9b778"],["1cb8a865.0626e","b8d93072.96554"],["40fc6ce6.1e7894"],["f914c5ae.b48238","b1d6b33a.75dde"],["edbd04e3.493418","43f4640a.f9a5e4"],[],["ca482de5.6adff","255c1bc0.0a37ac"],["67230c1b.3a1fdc","18874ebf.d7d419"],["693f6ebf.6b1928","548021b4.af1f68"]]},{"id":"6c6b14e2.33d194","type":"api-current-state","z":"5f403e00.def6","name":"","server":"2f469d31.dfdb72","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_select.modus","state_type":"str","state_location":"","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":570,"y":860,"wires":[["eefef968.c1a9b"]]},{"id":"feaf93cf.6ac408","type":"api-current-state","z":"5f403e00.def6","name":"","server":"2f469d31.dfdb72","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_select.modus","state_type":"str","state_location":"","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":550,"y":1800,"wires":[["c716bd20.660d88"]]},{"id":"c716bd20.660d88","type":"switch","z":"5f403e00.def6","name":"MODUS SWITCH","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Morning","vt":"str"},{"t":"eq","v":"Day","vt":"str"},{"t":"eq","v":"Evening","vt":"str"},{"t":"eq","v":"Night","vt":"str"},{"t":"eq","v":"DeepNight","vt":"str"},{"t":"eq","v":"Away","vt":"str"},{"t":"eq","v":"MovieTime","vt":"str"},{"t":"eq","v":"Alarm","vt":"str"},{"t":"eq","v":"Clean","vt":"str"}],"checkall":"true","repair":false,"outputs":9,"x":830,"y":1800,"wires":[["30db77cc.5f4c2","1ea0d903.a38bdf","1d6b8346.522a05"],["9d6e18cd.871098","83237d2d.de1e18","22e71d39.de134a"],["5a074ca5.6bc9ac","b0bd86fd.703808","69ec38eb.7e7a"],["f57feaf6.f58ab8","e68f5571.f1e1c","980ad42b.7f6a7"],["878ee2ea.9e3cd","b260a633.22a83","7a44c8f3.2c21c8"],[],["b8f7e1f4.e6f6b8","3ccd98ba.d06658","3fb45f32.30e63"],["ee7ded7c.56d498","405b5d24.9a8bc4","d97e7801.d8e5e"],["cfc66960.dffd78","35e5fd55.09ba7a","15b35b57.10c245"]]},{"id":"1f1f0015.4e84c","type":"api-call-service","z":"5f403e00.def6","name":"Hallway Cealing Light ON","server":"2f469d31.dfdb72","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"switch.hallway_cealing_lights","data":"","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":3350,"y":1380,"wires":[[]]},{"id":"da95fa97.79f898","type":"api-call-service","z":"5f403e00.def6","name":"Hallway Cealing Light OFF","server":"2f469d31.dfdb72","version":1,"debugenabled":false,"service_domain":"light","service":"turn_off","entityId":"switch.hallway_cealing_lights","data":"","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":3350,"y":1420,"wires":[[]]},{"id":"5f6d064c.e1cdc","type":"api-call-service","z":"5f403e00.def6","name":"Picture Light","server":"2f469d31.dfdb72","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.color_temperature_light_13","data":"{ \"entity_id\": \"light.color_temperature_light_13\", \"brightness_pct\": {{payload}}}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":3180,"y":920,"wires":[[]]},{"id":"f5f729a1.a0bbd","type":"api-call-service","z":"5f403e00.def6","name":"Picture Light 3","server":"2f469d31.dfdb72","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.color_temperature_light_13","data":"{ \"entity_id\": \"light.color_temperature_light_13\", \"brightness_pct\": {{payload}}}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":3180,"y":960,"wires":[[]]},{"id":"673a59b0.12e91","type":"api-call-service","z":"5f403e00.def6","name":"Picture Light","server":"2f469d31.dfdb72","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.hallway_picture_light_4","data":"{ \"entity_id\": \"light.color_temperature_light_14\", \"color_temp\": 300, \"brightness_pct\": {{payload}}}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":3180,"y":1000,"wires":[[]]},{"id":"caba2b35.37a9f","type":"api-call-service","z":"5f403e00.def6","name":"Stand Light 1","server":"2f469d31.dfdb72","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.hallway_standlight_1","data":"","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":3180,"y":1080,"wires":[[]]},{"id":"fd7f51aa.e98458","type":"api-call-service","z":"5f403e00.def6","name":"Stand Light 2","server":"2f469d31.dfdb72","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.hallway_standlight_2","data":"","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":3180,"y":1120,"wires":[[]]},{"id":"6339d512.ddf86c","type":"api-call-service","z":"5f403e00.def6","name":"Hallway Small Ball Light","server":"2f469d31.dfdb72","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.hallway_small_ball_light","data":"","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":3220,"y":1200,"wires":[[]]},{"id":"6768cd33.a561a4","type":"api-call-service","z":"5f403e00.def6","name":"Hallway under Bench light","server":"2f469d31.dfdb72","version":1,"debugenabled":false,"service_domain":"","service":"","entityId":"light.hue_lightstrip_plus_1_4","data":"","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":3220,"y":1240,"wires":[[]]},{"id":"a26284c4.9effa","type":"api-call-service","z":"5f403e00.def6","name":"Hallway under Bench light","server":"2f469d31.dfdb72","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.hue_lightstrip_plus_1_2","data":"{ \"entity_id\": \"light.hue_lightstrip_plus_1_2\", \"brightness_pct\": {{payload}}}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":3220,"y":1280,"wires":[[]]},{"id":"1d680049.779118","type":"inject","z":"5f403e00.def6","name":"","props":[{"p":"pct","v":"100","vt":"num"},{"p":"temp","v":"500","vt":"num"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payloadType":"str","x":2070,"y":380,"wires":[["a8d9ef97.d9b47"]]},{"id":"68d2f405.49d0a4","type":"api-call-service","z":"5f403e00.def6","name":"Hallway Big ball Light","server":"2f469d31.dfdb72","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.hallway_stand_light","data":"","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":3210,"y":1160,"wires":[[]]},{"id":"a7e83852.2c2e5","type":"api-call-service","z":"5f403e00.def6","name":"Hallway under Bench light","server":"2f469d31.dfdb72","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.hue_lightstrip_plus_1_2","data":"{ \"entity_id\": \"light.hue_lightstrip_plus_1_2\", \"brightness_pct\": {{payload}}}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":3220,"y":1320,"wires":[[]]},{"id":"798dde79.08019","type":"inject","z":"5f403e00.def6","name":"","props":[{"p":"pct","v":"5","vt":"num"},{"p":"temp","v":"250","vt":"num"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payloadType":"str","x":2070,"y":340,"wires":[["a8d9ef97.d9b47"]]},{"id":"a8d9ef97.d9b47","type":"api-call-service","z":"5f403e00.def6","name":"Picture Light","server":"2f469d31.dfdb72","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.hallway_picture_light_1","data":"{ \"entity_id\": \"light.color_temperature_light_10\",\"brightness_pct\": {{pct}}, \"color_temp\": {{temp}} }","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":2500,"y":340,"wires":[[]]},{"id":"1e9d502.6aad0b","type":"api-current-state","z":"5f403e00.def6","name":"Morning pct","server":"2f469d31.dfdb72","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_number.light_brightness_morning","state_type":"str","state_location":"statepct","override_payload":"msg","entity_location":"pct","override_data":"msg","blockInputOverrides":false,"x":1830,"y":500,"wires":[["df155fa6.375e18"]]},{"id":"1ea0d903.a38bdf","type":"api-current-state","z":"5f403e00.def6","name":"Morning pct off","server":"2f469d31.dfdb72","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_number.light_brightness_morning_off","state_type":"str","state_location":"pct","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1840,"y":1440,"wires":[["e70ff033.d90a4"]]},{"id":"40fc6ce6.1e7894","type":"api-current-state","z":"5f403e00.def6","name":"Evening pct","server":"2f469d31.dfdb72","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_number.light_brightness_evening","state_type":"str","state_location":"pct","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1830,"y":700,"wires":[["df155fa6.375e18"]]},{"id":"b0bd86fd.703808","type":"api-current-state","z":"5f403e00.def6","name":"Evening pct","server":"2f469d31.dfdb72","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_number.light_brightness_evening_off","state_type":"str","state_location":"pct","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1830,"y":1760,"wires":[["e70ff033.d90a4"]]},{"id":"b8d93072.96554","type":"api-current-state","z":"5f403e00.def6","name":"Day pct","server":"2f469d31.dfdb72","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_number.light_brightness_day","state_type":"num","state_location":"datapct","override_payload":"msg","entity_location":"pct","override_data":"msg","blockInputOverrides":false,"x":1820,"y":600,"wires":[["df155fa6.375e18"]]},{"id":"83237d2d.de1e18","type":"api-current-state","z":"5f403e00.def6","name":"Day pct","server":"2f469d31.dfdb72","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_number.light_brightness_day_off","state_type":"num","state_location":"statepct","override_payload":"msg","entity_location":"pct","override_data":"msg","blockInputOverrides":false,"x":1820,"y":1600,"wires":[["e70ff033.d90a4"]]},{"id":"f914c5ae.b48238","type":"api-current-state","z":"5f403e00.def6","name":"Night pct","server":"2f469d31.dfdb72","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_number.light_brightness_night","state_type":"str","state_location":"pct","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1820,"y":800,"wires":[["df155fa6.375e18"]]},{"id":"e68f5571.f1e1c","type":"api-current-state","z":"5f403e00.def6","name":"Night pct","server":"2f469d31.dfdb72","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_number.light_brightness_night_off","state_type":"str","state_location":"pct","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1820,"y":1920,"wires":[["e70ff033.d90a4"]]},{"id":"edbd04e3.493418","type":"api-current-state","z":"5f403e00.def6","name":"Deep Night pct","server":"2f469d31.dfdb72","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_number.light_brightness_deep_night","state_type":"str","state_location":"pct","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1840,"y":900,"wires":[["df155fa6.375e18"]]},{"id":"b260a633.22a83","type":"api-current-state","z":"5f403e00.def6","name":"Deep Night pct","server":"2f469d31.dfdb72","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_number.light_brightness_deep_night_off","state_type":"str","state_location":"pct","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1840,"y":2080,"wires":[["e70ff033.d90a4"]]},{"id":"3ccd98ba.d06658","type":"api-current-state","z":"5f403e00.def6","name":"Movie time pct","server":"2f469d31.dfdb72","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_number.light_brightness_movietime_off","state_type":"str","state_location":"pct","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1840,"y":2240,"wires":[["e70ff033.d90a4"]]},{"id":"ca482de5.6adff","type":"api-current-state","z":"5f403e00.def6","name":"Movie time pct","server":"2f469d31.dfdb72","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_number.light_brightness_movietime","state_type":"str","state_location":"pct","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1840,"y":1000,"wires":[["df155fa6.375e18"]]},{"id":"67230c1b.3a1fdc","type":"api-current-state","z":"5f403e00.def6","name":"Alarm","server":"2f469d31.dfdb72","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_number.light_brightness_alarm","state_type":"str","state_location":"pct","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1810,"y":1100,"wires":[["df155fa6.375e18"]]},{"id":"ee7ded7c.56d498","type":"api-current-state","z":"5f403e00.def6","name":"Alarm","server":"2f469d31.dfdb72","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_number.light_brightness_alarm_off","state_type":"str","state_location":"pct","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1810,"y":2400,"wires":[["e70ff033.d90a4"]]},{"id":"693f6ebf.6b1928","type":"api-current-state","z":"5f403e00.def6","name":"Clean","server":"2f469d31.dfdb72","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_number.light_brightness_clean","state_type":"str","state_location":"pct","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1810,"y":1200,"wires":[["df155fa6.375e18"]]},{"id":"cfc66960.dffd78","type":"api-current-state","z":"5f403e00.def6","name":"Clean","server":"2f469d31.dfdb72","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_number.light_brightness_clean_off","state_type":"str","state_location":"pct","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1810,"y":2600,"wires":[["e70ff033.d90a4"]]},{"id":"67e15122.f9b778","type":"api-current-state","z":"5f403e00.def6","name":"Morning temp","server":"2f469d31.dfdb72","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_number.light_temp_morning","state_type":"num","state_location":"state","override_payload":"msg","entity_location":"temp","override_data":"msg","blockInputOverrides":false,"x":1840,"y":460,"wires":[["41c6dc36.3191b4"]]},{"id":"1cb8a865.0626e","type":"api-current-state","z":"5f403e00.def6","name":"Day pct","server":"2f469d31.dfdb72","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_number.light_temp_day","state_type":"num","state_location":"state","override_payload":"msg","entity_location":"temp","override_data":"msg","blockInputOverrides":false,"x":1820,"y":560,"wires":[["9e3ea328.044f18"]]},{"id":"b1d6b33a.75dde","type":"api-current-state","z":"5f403e00.def6","name":"Evening pct","server":"2f469d31.dfdb72","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_number.light_temp_evening","state_type":"str","state_location":"state","override_payload":"msg","entity_location":"temp","override_data":"msg","blockInputOverrides":false,"x":1830,"y":660,"wires":[["ee653cd.81a7dc"]]},{"id":"43f4640a.f9a5e4","type":"api-current-state","z":"5f403e00.def6","name":"Night pct","server":"2f469d31.dfdb72","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_number.light_temp_night","state_type":"str","state_location":"state","override_payload":"msg","entity_location":"temp","override_data":"msg","blockInputOverrides":false,"x":1820,"y":760,"wires":[["e5fd5f69.97598"]]},{"id":"6c879d3f.0f7ebc","type":"api-current-state","z":"5f403e00.def6","name":"Deep Night pct","server":"2f469d31.dfdb72","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_number.light_temp_deep_night","state_type":"str","state_location":"state","override_payload":"msg","entity_location":"temp","override_data":"msg","blockInputOverrides":false,"x":1840,"y":860,"wires":[["b0c85c0d.0b1568"]]},{"id":"255c1bc0.0a37ac","type":"api-current-state","z":"5f403e00.def6","name":"Movie time pct","server":"2f469d31.dfdb72","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_number.light_temp_movietime","state_type":"str","state_location":"state","override_payload":"msg","entity_location":"temp","override_data":"msg","blockInputOverrides":false,"x":1840,"y":960,"wires":[["96b618a7.9bd068"]]},{"id":"18874ebf.d7d419","type":"api-current-state","z":"5f403e00.def6","name":"Alarm","server":"2f469d31.dfdb72","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_number.light_temp_alarm","state_type":"str","state_location":"state","override_payload":"msg","entity_location":"temp","override_data":"msg","blockInputOverrides":false,"x":1810,"y":1060,"wires":[["f08f23fe.0055f8"]]},{"id":"548021b4.af1f68","type":
