For several years I have been using:
turn_{{payload}}
In the service Field and have had NOTHING in the Data Field.
Now it appears I have MANY nodes failing apparently requiring something int he Data Field.
Anny Ideas?
turn_{{payload}}
Anny Ideas?
What versions of HA / companion / NR / WebSocket are you on?
There have been major changes to the way services are managed in HA to permit / require responses. As HA has moved forwards on this the other components have to be updated accordingly.
I cannot replicate your issue.
Does this apply for all the entities in your list if tested one at a time?
EDIT.
Yes I have replicated it. I was using my independent Pi which was up to date.
Updating my HA - update Node-RED addon does not update the WebSocket nodes and I was getting the entry error for either JSON or JSONata at this point.
Solution - update WebSocket nodes to the latest version.
Thanks for the repsonse!
I updated node-red and booted and I think it is ok now.
Not sure what the issues was or how it went away.
