The notification is sent but no image is included.
Does anyone have any idea what I am doing wrong? I have tested the {{ states.camera… }} variable interpolation in other fields (for example including the same variable in the “message” body and it DOES interpolate the variable. I have also tested using the absolute URL to a publicly available image as the value to the “image” property and this DOES work too.
Does anyone have any ideas what I might be doing wrong?
Edit: for the avoidance of doubt the “data” attribute is type JSON, not J-expression.
Your example is the first use of $entities that I have stumbled across. Is there some documentation that you are aware of that illustrates its use (and maybe other useful global variables)?
Hi
I’m using the notify service in Nodered to send an email when an alarm was triggerered. It worked for a long time. But now Nodered shows an API errror. Probably after a recent upgrade
What shoud I do?
This is my configuration file. Before i used gmail to send the email, which was working fine, but not anymore probably since an update. So today, I tried with my private account and I still have the same problem (API error)
It’s been a while since I last tried streaming to the ha app. I gave up on it because there was lag. Instead I use a command to open the official app if I need to see the video. Clicking the text itself will open dahua’s app.
