Call Service on Blueprint isn't actually being executed?
I’ve configured this knob blueprint Zigbee2MQTT Tuya Moes Smart Knob (ERS-10TZBVK-AA) to call media_player methods on button press and rotate left/right as follows
use_blueprint:
  path: rdeangel/zigbee2mqtt-tuya-moes-smart-knob-ers-10tzbvk-aa.yaml
  input:
    switch: sensor.mando_circular_action
    button_rotate_right:
      - service: media_player.volume_up
        data: {}
          entity_id: media_player.altavoces_despacho
    button_rotate_left:
      - service: media_player.volume_down
        data: {}
    button_short_press:
      - service: media_player.media_pause
        data: {}
    button_double_press:
      - service: media_player.media_play
        data: {}
    button_long_press:
        data: {}
If i check on traces i can see that the event is properly captured and routed as expedted to call the desired service method in near real time, but it almost never actually does play/pause/volup/voldown… and when it does, it happens with a couple of secs of delay.
If i manipulate this entity media_player.altavoces_despacho through the media card in lovelace, it works flawlessly with 0 delay.
This entity is a pair of Google Nest speakers setup through Google Cast integration.
How can i debug further to find out where’s the issue??
Kind regards,
Check with the link you posted
The BP is broken, follow up there.
Thanks a lot for your fast and accurate support!!!
