It unit is accessible as I can action the turn_off and turn_on service. Its just the process for setting modes Im not yet clear on. (ie its not actually changing from low to high)
Thanks in advance
alias: New Script
sequence:
- service: climate.set_fan_mode
fan_mode: high
device_id: 45f0d25ee6189e6e8aexxxxxxxxxxx
mode: single
alias: New Script
sequence:
- service: climate.set_hvac_mode
hvac_mode: heat_cool
mode: single
Ive posted hvac mode as well - setting that does change the unit mode, whereas fan_mode doesnt change.
Ive only tried fan_mode first in NR assuming it was probably the easier one. Ill try the other services instead in case its just a peculiarity with fan mode.
NR just calls the service in HA, so if the HA call fails, then start to look at HA only.
Just test that you can call it from the developer tools in HA.
Sorted thanks, it was just a capitalization issue with Low vs low that I found when I checked developer attributes
For some reason those values have capitals and I missed that fact
