Call to /api/alexa/returns 400 error
A recent Home Assistant update appears to have broken my Alexa skills (via Lamda functon on AWS). I’m following the instructions here.
If I visit /api/alexa/ I get a 400 error.
The lambda function returns the error SpeechletResponse was null
It was working as of 2021.4.x
BTW, I checked my SSL cert (LetsEncrypt via the NGINX Proxy Manager add-on) from outside my home network and it is valid.
Same issue here. I am not using /api/alexa/smart_home, but api/alexa as described here:
This issue has returned for me with 2022.2.0. Still occurs with 2022.2.1
If I go to https://myhomeassistantinstance/api/alexa , I get a 400 error and my custom skills have stopped working. Anyone else having this issue? I can’t find anything in breaking changes that addresses this.
Stupid me didn’t respond to this thread with whatever happened to fix the issue for me last May :frowning:
There is indeed changed something in that API url…
I was using Google assistant , with nabucasa and google the local edition… 2 editions
Seems when I now browse to that API page it returns 404 not found, seems component was not loaded…
It needs to be 405…
For some reason since 2022 , in can’t have 2 smart home Assistants loaded, I disabled the nabucasa , as soon as I disable it and I go back to the API page, it get back with an 405 for me …
When I roll back to 2021 , it works for both, if I upgrade to 2022, issue is back
Not sure if it’s related to Alexa also, but there is indeed something changed in the API strings
@pergola.fabio I created an issue on GitHub. Consider giving it a thumbs-up:
Yeah, but not 100% sure it it’s related
Fixed as of 2022.2.8 It was an issue with the setup phase of the cloud component.
