Callback constraints not working with input_boolean?
I can’t seem to get the input_boolean to affect the motion sensors, that is, to not have them run when the input_boolean is set to off. Here’s what’s happening:
I’m using the example app for motion_lights as written here: https://github.com/home-assistant/appdaemon/blob/dev/conf/example_apps/motion_lights.py
In my app.yaml file, I’m using the following configuration:
basement_motion:
  module: motion_lights
  class: MotionLights
  sensor: binary_sensor.basement_motion_sensor
  entity_on: switch.basement
  entity_off: switch.basement
  delay: 60
  constrain_input_boolean: input.boolean.basement_sensor
The input boolean is as follows:
basement_sensor:
      initial: on
      icon: mdi:track-light
With it set to on, the motion sensor works as expected. However, when I turn it off, the motion sensor is still active and still turns the lights on. Am I missing something? I’m very new to AppDaemon, so I very well may be missing something.
I think you need input_boolean.basement_sensor, but I’m surprised what you have doesn’t throw up an error.
@gpbenton Meaning not use the “input_boolean.” part of “input_boolean.basement_sensor”?
I tried that too after seeing your comment and I’m still having the same issue. The input_boolean was turned off but the motion sensor still turned the light on. No errors coming up in the logs in Docker.
No, I mean use an _ in input_boolean rather than the . you had used in your yaml.
Despite the lack of error in the logs, that appeared to be the issue. There’s something about someone else looking at your code that makes everything clearer. Much appreciated, @gpbenton!
