CallerID and TTS - how to say each number individually in the phone number?
I’m a brand new HA user (about two weeks). I’m using HA on a generic x86-64 box.
Some of the automations that I want to do revolve around using CallerID. I do have a notification automation going for pushing a message to my iPhone, and that is working great.
I also have an automation using TTS (via Google Translate) to speak the message to my HomePod. This also is working, but the TTS does one thing that I want to do differently - it speaks the numbers as a group, and not individually. For instance, it speaks 8001234567 as “8 billion, 1 million, 2 hundred 34 thousand, 5 hundred 67”.
Since people don’t think of phone numbers in this way, I want to change it to say this number as “eight zero zero one two three four five six seven”.
The yaml for this automation is:
service: tts.speak
  entity_id: tts.google_en_com
  cache: false
  media_player_entity_id: media_player.living_room_homepod
  message: >-
    Incoming call from {{
    state_attr('sensor.modem_callerid_55ff3d54501b4d361c7abf6327d7405d',
    'cid_name') }} at {{
    'cid_number') }}
In playing around in the developer tools with TTS, I have found that if I insert a space between each number (so it is “8 0 0 1 2 3 4 5 6 7”), it will speak it as I desire.
In playing around at W3Schools Tryit Editor, I was able to create this simple python code to accomplish what I’m trying to do:
Value=str(8001234567)
Result=""
for x in Value:
  Result = Result + " " + x
print (Result)
print (Result[1:])
I’ve also looked into whether there is an option in the API to speak each number, but I don’t see anything like this (of course not, that would make sense, right?).
I’ve been running into issues trying to implement this in HA. When using the UI, I switch to YAML to type the code in, and then it disappears on me after saving and closing it.
Can anyone give this newby a helping hand?
Thanks!
Wayne
try:
{{ state_attr(‘sensor.modem_callerid_55ff3d54501b4d361c7abf6327d7405d’,
‘cid_number’) | replace(‘’,’ ') }}
That is so beautifully simple, and it works.
I had found several similar posts on the internet, but never a solution.
Thanks, Brian!
