Using this code, it is still erroring about being on a thread and I should use add_job, but I am using add_job? Any idea why this is failing?
def _update_config_entry():
hass.config_entries.async_update_entry(
config_entry,
data={**config_entry.data, "entity_ts": datetime.now(UTC)},
def _async_registry_updated(event: Event[EventEntityRegistryUpdatedData]) -> None:
# Reload entities and then update the other pieces of the system.
_LOGGER.debug(
"%s: Updateing entity from area change", config_entry.data[CONF_NAME]
hass.add_job(_update_config_entry)
calls hass.config_entries.async_update_entry from a thread. For more information, see Thread Safety with asyncio | Home Assistant Developer Docs at custom_components/simply_magic_areas/init.py,
