I’m making a battery-powered button box, using an ESP32 and three buttons. The idea is, it would sleep basically all the time, and pushing a button would wake it (using esp32_ext1_wakeup’s ANY_HIGH mode) and send an MQTT message announcing which button was pushed.
Using information from this useful topic I have it working on an ESP32-WROVER-B module. Now I’m trying to implement it on an ESP-WROOM-32 module (presumably older) and failing.
The problem is, my lambda calling esp_sleep_get_ext1_wakeup_status() always returns 0 on the WROOM module; on the WROVER module it returns the GPIO pin number. This esp32 discussion includes, “Yes rev0 silicon has a bug where you have to run the default wake stub when coming out of deepsleep. So if you set a custom stub you should call the default from it.” I’m guessing that’s my problem; that somehow I need to “run the default wake stub.”
So… (I’m over my head here): I need to call esp_default_wake_deep_sleep() somewhere (?). However, if I change my lambda from:
on_boot:
priority: 900
then:
- lambda: |-
id(wake_up_reason) = esp_sleep_get_ext1_wakeup_status();
to:
- lambda: |-
esp_default_wake_deep_sleep();
I get a module panic, including a long dump of warnings, brownout detections, and on and on.
Help?
Thanks,
Tim
