Hey guys, I am trying to run a script via the repeat action within an automation but it only runs once.
alias: TEST
description: ''
- platform: sun
event: sunset
condition: []
- repeat:
count: '2'
sequence:
- service: script.wled_routine
data: {}
- delay: '00:05:00'
mode: single
It should run the script twice, separated by five minutes, right?
I see this in the logs:
TEST: Repeat at step 1: Error executing script. Unexpected error for call_service at pos 1: coroutine raised StopIteration
TEST: Error executing script. Unexpected error for repeat at pos 1: coroutine raised StopIteration
While executing automation automation.test
Does anyone have an idea why the repeat is failing to run?
I think it may be something in script, but I don’t know what. Sometimes it errors, sometimes it doesn’t.
Here’s the script:
alias: WLED routine
sequence:
- data_template:
entity_id: all
effect: '{{ state_attr("light.wled_living_room", "effect_list") | random }}'
intensity: '{{ (range(50, 200)|random) }}'
service: wled.effect
- data_template:
entity_id: light.wled_living_room
speed: '{{ (range(50, 200)|random) }}'
palette: '{{state_attr("input_select.wled_palettes", "options") | random }}'
- data_template:
entity_id: light.wled_balcony_upper
- data_template:
entity_id: light.wled_balcony_lower
- data_template:
entity_id: light.wled_tree
- service: media_player.play_media
media_content_id: 'http://192.168.1.24:8123/local/audio/sounds/discord_ping.mp3'
media_content_type: audio/mp3
entity_id: media_player.living_room_speaker
- service: notify.lg_tv
message: WLED single run compete
mode: restart
icon: 'mdi:led-strip-variant'
max: 5
tom_l
November 7, 2020, 4:16am
3
Try:
- repeat:
count: '2'
sequence:
- service: script.turn_on
entity_id: script.wled_routine
Reason: https://www.home-assistant.io/integrations/script/#waiting-for-script-to-complete
(Taras)
November 7, 2020, 4:48am
5
Can you explain how that reason affects this situation (only one iteration when there ought to be two)?
This calls the script and waits for it to finish before executing the delay and waiting for 5 minutes.
This calls the script and immediately executes the delay and waits for 5 minutes.
How does that affect the number of iterations performed? As far as I can tell, the wled_routine
script contains no delays and should execute and complete quickly (i.e. well within the 5 minutes before the next iteration should occur).
What have I missed here?
tom_l
November 7, 2020, 4:56am
6
No, no I can not.
It was just something I thought worth a try.
I probably should have said “possible reason”.
