ashscott
(Ash)
November 7, 2019, 8:59pm
1
Following this guide , I am trying to call a script and pass it variables.
I’m calling it with:
- service: script.notify
speaker: 'media_player.kitchen_speaker'
message: 'Xmas lights have been turned off'
The script is as below:
notify:
alias: "Notifications"
fields:
speaker:
message:
sequence:
- service: tts.google_say
data_template:
entity_id: "{{ speaker }}"
message: "{{ message }}"
- service: notify.lounge_tv
data_template:
- service: notify.mobile_app_iphone
data_template:
title: "{{ message }}"
With the fields property in the script I get the following config error:
Invalid config for [script]: [fields] is an invalid option for [script]. Check: script->script->notifications->fields. (See /Users/ashscott/.homeassistant/configuration.yaml, line 245). Please check the docs at https://home-assistant.io/components/script/
I’m stumped as to why it won’t work.
Any suggestions anyone?
notify:
sequence:
data_template:
data_template:
data_template:
ashscott
(Ash)
November 8, 2019, 5:47am
3
Thank you, Marc.
That’s what I started with but the docs call for the fields and when I include them I get the config error.
Either way it doesn’t work as expected.
ashscott
(Ash)
November 8, 2019, 6:51am
4
Turns out that ‘reload scripts’ and ‘reload automations’ wasn’t enough to have this work. A full restart was required.
In summary, the correct code is as below, if it helps anyone else.
Automation:
Script
notify:
sequence:
data_template:
data_template:
data_template:
I’m trying to do something similar, but for integer. Can anyone say what is wrong in this code?
- platform: state
entity_id: sensor.vallox_outdoor_air
condition:
- choose:
- conditions:
- condition: numeric_state
below: '-20'
sequence:
- service: script.turn_on
entity_id: script.set_fan_speed
power_percent: '50'
I have verified that the conditions above are met by toggling state of my Hue lamps.
And the script:
set_fan_speed:
alias: Setting fan speed...
sequence:
- service: vallox.set_profile_fan_speed_home
data: #tried also data_template:
fan_speed: '{{ power_percent }}'
mode: single
Running following script seems to work, so the problem is that delivering the parameter does not work.
set_fan_speed:
sequence:
fan_speed: '50'
mode: single
Thanks!
Tried casting too, still no luck:
set_fan_speed:
sequence:
data_template:
fan_speed: '{{ power_percent|int }}'
mode: single
Anyone able to help?
Ok I solved it. Just in case someone else is wondering the same thing, the problem was how I called the script. The correct way (well, working at least) is as follows:
- platform: state
condition:
- choose:
- conditions:
below: '-20'
sequence:
- service: script.set_fan_speed
power_percent: '50'
The difference is that I don’t call
script.turn_on
but
The script that works with this is:
set_fan_speed:
sequence:
data_template:
mode: single
