This is something weird I noticed after moving from Docker and deCONZ (if that matters) to hassOS and ZHA:
If I turn on a light via automation (AppDaemon in my case, but also if I just do from service call in Developer Tools
→ Services
), I can’t turn on at low brightness (brightness=1
). If I try, it turns on significantly brighter, closer to 50%.
The extra weird thing is that in the UI, it shows that it is on at brightness=1
, but if I “increase” that to brightness=2
with the slider, it dims to almost nothing (so actually setting the brightness to 2).
service: homeassistant.turn_on
data: {brightness: 1, kelvin: 2200}
entity_id: light.kitchen_spot_5
(the exact same happens if I use service: light.turn_on
So if I click “Call Service” with the above code, it turns on at ~50%, while showing 1 in the UI. If I click “Call Service” again on the same code, it actually dims to brightness=1
(or at least what looks like it).
Why the heck does it do that? And how to I stop it?
