Hi !
I found that the component doesn’t deal with the fact that I disabled the volume management on my cxn… Quick dirty fix; I deleted everything regarding the volume ! :stuck_out_tongue
here is my file /config/custom_components/cambridge_cxn/media_player.py
Support for interface with a Cambridge Audio CXN media player.
For more details about this platform, please refer to the documentation at
https://github.com/lievencoghe/cambridge_cxn
import json
import logging
import urllib.request
import requests
import uuid
import voluptuous as vol
from homeassistant.components.media_player import MediaPlayerDevice, PLATFORM_SCHEMA
from homeassistant.components.media_player.const import (
SUPPORT_PAUSE,
SUPPORT_PLAY,
SUPPORT_STOP,
SUPPORT_PREVIOUS_TRACK,
SUPPORT_NEXT_TRACK,
SUPPORT_SELECT_SOURCE,
SUPPORT_TURN_OFF,
SUPPORT_TURN_ON,
from homeassistant.const import CONF_HOST, CONF_NAME, STATE_OFF, STATE_ON, STATE_PAUSED, STATE_PLAYING, STATE_IDLE, STATE_STANDBY
import homeassistant.helpers.config_validation as cv
__version__ = "0.1"
_LOGGER = logging.getLogger(__name__)
SUPPORT_CXN = (
SUPPORT_PAUSE
| SUPPORT_PLAY
| SUPPORT_STOP
| SUPPORT_NEXT_TRACK
| SUPPORT_TURN_OFF
| SUPPORT_TURN_ON
DEFAULT_NAME = "Cambridge Audio CXN"
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend(
vol.Required(CONF_HOST): cv.string,
vol.Optional(CONF_NAME, default=DEFAULT_NAME): cv.string,
def setup_platform(hass, config, add_devices, discovery_info=None):
host = config.get(CONF_HOST)
name = config.get(CONF_NAME)
if host is None:
_LOGGER.error("No Cambridge CXN IP address found in configuration file")
return
add_devices([CambridgeCXNDevice(host, name)])
class CambridgeCXNDevice(MediaPlayerDevice):
def __init__(self, host, name):
"""Initialize the Cambridge CXN."""
_LOGGER.info("Setting up Cambridge CXN")
self._host = host
self._mediasource = ""
self._name = name
self._pwstate = "NETWORK"
self._should_setup_sources = True
self._source_list = None
self._source_list_reverse = None
self._state = STATE_OFF
self._media_title = None
self._media_artist = None
self._artwork_url = None
_LOGGER.debug(
"Set up Cambridge CXN with IP: %s", host,
self.update()
def _setup_sources(self):
_LOGGER.debug("Setting up CXN sources")
sources = json.loads(
urllib.request.urlopen(
"http://" + self._host + "/smoip/system/sources"
).read()
)["data"]
sources2 = sources.get("sources")
self._source_list = {}
self._source_list_reverse = {}
for i in sources2:
_LOGGER.debug("Setting up CXN sources... %s", i["id"])
source = i["id"]
configured_name = i["name"]
self._source_list[source] = configured_name
self._source_list_reverse[configured_name] = source
def media_play_pause(self):
self.url_command("smoip/zone/play_control?action=toggle")
def media_next_track(self):
self.url_command("smoip/zone/play_control?skip_track=1")
def media_previous_track(self):
self.url_command("smoip/zone/play_control?skip_track=-1")
def update(self):
self._pwstate = json.loads(
"http://" + self._host + "/smoip/system/power"
).read()
)["data"]["power"]
self._mediasource = json.loads(
urllib.request.urlopen("http://" + self._host + "/smoip/zone/state").read()
)["data"]["source"]
playstate = urllib.request.urlopen("http://" + self._host + "/smoip/zone/play_state").read()
try:
self._media_title = json.loads(playstate)["data"]["metadata"]["title"]
except:
try:
self._media_artist = json.loads(playstate)["data"]["metadata"]["artist"]
except:
try:
urllib.request.urlretrieve(json.loads(playstate)["data"]["metadata"]["art_url"], "/config/www/cxn-artwork.jpg")
self._artwork_url = "/local/cxn-artwork.jpg?" + str(uuid.uuid4())
except:
self._state = json.loads(playstate)["data"]["state"]
if self._should_setup_sources:
self._setup_sources()
self._should_setup_sources = False
def url_command(self, command):
"""Establish a telnet connection and sends `command`."""
_LOGGER.debug("Sending command: %s", command)
urllib.request.urlopen("http://" + self._host + "/" + command).read()
@property
def name(self):
"""Return the name of the device."""
return self._name
@property
def source_list(self):
return sorted(list(self._source_list.values()))
@property
def state(self):
if self._pwstate == "NETWORK":
return STATE_OFF
if self._pwstate == "ON":
if self._state == "play":
return STATE_PLAYING
elif self._state == "pause":
return STATE_PAUSED
elif self._state == "stop":
return STATE_IDLE
else:
return STATE_ON
return None
@property
def supported_features(self):
return SUPPORT_CXN
@property
def media_title(self):
return self._media_title
@property
def media_artist(self):
return self._media_artist
@property
def media_image_url(self):
_LOGGER.debug("CXN Artwork URL: %s", self._artwork_url)
return self._artwork_url
def select_source(self, source):
reverse_source = self._source_list_reverse[source]
if reverse_source in [
"AIRPLAY",
"CAST",
"IR",
"MEDIA_PLAYER",
"SPDIF_COAX",
"SPDIF_TOSLINK",
"SPOTIFY",
"USB_AUDIO",
"ROON"
self.url_command("smoip/zone/state?source=" + reverse_source)
else:
self.url_command("smoip/zone/recall_preset?preset=" + reverse_source)
#def set_volume_level(self, volume):
# vol_str = "smoip/zone/state?volume_percent=" + str(int(volume * 100))
# self.url_command(vol_str)
def turn_on(self):
self.url_command("smoip/system/power?power=ON")
def turn_off(self):
self.url_command("smoip/system/power?power=NETWORK")
