Hi
I have IP camera install in my home i wanted to know to get camera feed integrated to my hassio homescreen
Hi
Hi @samiraa78 !
The answer to your question (inquiry?) has already been richly described. Just take a look at camera component. I suppose generic IP camera will interest you the most.
thanks i will try again but last time i tried it my camera stopped working all together giving me a password error
Depending on the cameras make and model, you might be able to reset the camera to factory settings, wiping the password (or restoring default).
thanks mine seems to have none lol stil searching though
I run zoneminder on a separate pc and then use the zoneminder component:
thanks will install the same need to buy another pi for that
I’m sure it depends on how many cameras you run but I am not sure that a RPi3 will run ZM very well. I currently use an old i3 desktop with 11 cameras (9 recording) and the processor stays fairly occupied.
I actually dont want to record as I already have an NVR for the cameras I just want to get the feed from them however there wont be more then 4 camera
Did you figure this out? I want to do the same, but I must be missing something
