I just installed Home Assistant on a Raspberry Pi 4, 4gb. It is running Home Assistant 2023.9.3 and says there are not available updates. I have it connected to two Tuya 360 Panoramic Bulb Cameras, and OctoPrint. I can turn the Tuya lights on in Home Assistant. I can control the printer in Home Assistant. The Tuya camera feeds are visible in the Tuya app. The OctoPrint camera feed is visible in its web ui. Home assistant just displays grey boxes for the cameras
edit: After checking logs it appeared that it was having problems connecting to the OctoPrint camera’s url. Using “Terminal & SSH” I found that it cannot resolve OctoPrint by name, but it is able to resolve the name server by name. I then added a MJPEG IP Camera, and pointed it to the OctoPrint stream by ip address, and that worked. I think the problem is likely IPv6, which I cannot disable. If anyone knows how to disable IPv6 that would be helpful, or has any other idea as to why it can’t resole by name.
