Hey guys, Im new to home assistant thing so please bear with me. I
m using home assistant on synology docker and Im trying to add my compro IP550 Camera to it for 4 days without success. On lovelace card I
m seeing the image but when I`m clicking on it I have a infinite loading circle. Here is my configuration.yaml:
ffmpeg:
ffmpeg_bin: /usr/bin/ffmpeg
stream:
camera: !include camera.yaml
config:
logbook:
mobile_app:
person:
ssdp:
system_health:
zeroconf:
discovery:
frontend:
javascript_version: latest
http:
base_url: http://192.168.2.4:8123
and my camera.yaml:
- platform: ffmpeg
input: -rtsp_transport tcp -i rtsp://user:[email protected]:554/medias1
extra_arguments: -pred 1 -q:v 2
name: Baby IP Camera
And here is some error log from infinite loading circle:
2019-10-11 23:22:09 ERROR (stream_worker) [homeassistant.components.stream.worker] Error demuxing stream: No dts in packet
2019-10-11 23:22:09 ERROR (MainThread) [aiohttp.server] Error handling request
File “/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py”, line 418, in start
resp = await task
File “/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py”, line 458, in _handle
resp = await handler(request)
File “/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py”, line 119, in impl
return await handler(request)
File “/usr/src/homeassistant/homeassistant/components/http/real_ip.py”, line 40, in real_ip_middleware
File “/usr/src/homeassistant/homeassistant/components/http/ban.py”, line 73, in ban_middleware
File “/usr/src/homeassistant/homeassistant/components/http/auth.py”, line 231, in auth_middleware
File “/usr/src/homeassistant/homeassistant/components/http/view.py”, line 128, in handle
result = await result
File “/usr/src/homeassistant/homeassistant/components/stream/core.py”, line 181, in get
return await self.handle(request, stream, sequence)
File “/usr/src/homeassistant/homeassistant/components/stream/hls.py”, line 36, in handle
body=renderer.render(track, utcnow()).encode(“utf-8”), headers=headers
File “/usr/src/homeassistant/homeassistant/components/stream/hls.py”, line 95, in render
+ self.render_playlist(track, start_time)
File “/usr/src/homeassistant/homeassistant/components/stream/hls.py”, line 67, in render_preamble
return ["#EXT-X-VERSION:3", f"#EXT-X-TARGETDURATION:{track.target_duration}"]
File “/usr/src/homeassistant/homeassistant/components/stream/core.py”, line 83, in target_duration
return round(sum(durations) // len(self._segments)) or 1
ZeroDivisionError: integer division or modulo by zero
On vlc is working fine, on android ip camera viewer is working fine, ios etc… but on hass not.
I was gonna try generic camera but from where should I get the still_image_url?
Btw my camera has upnp enabled but hass is not seeing it. Any help setting it right please?
