I’m getting infrequent erorrs while using the camera.local_file component.
ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.140154635488560] Error handling message: {'type': 'camera_thumbnail', 'entity_id': 'camera.local_file', 'id': 12493}
File "/usr/src/app/homeassistant/components/websocket_api/decorators.py", line 17, in _handle_async_response
await func(hass, connection, msg)
File "/usr/src/app/homeassistant/components/camera/__init__.py", line 463, in websocket_camera_thumbnail
image = await async_get_image(hass, msg['entity_id'])
File "/usr/src/app/homeassistant/components/camera/__init__.py", line 93, in async_get_image
image = await camera.async_camera_image()
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/src/app/homeassistant/components/camera/local_file.py", line 72, in camera_image
with open(self._file_path, 'rb') as file:
OSError: [Errno 9] Bad file descriptor
this is my config:
- platform: local_file
file_path: /config/tmp/latest.jpg
I’m scanning a camera picture via tensorflow for persons (via a motion trigger), and when a person is detected the picture is beeing saved:
image_processing:
- platform: tensorflow
scan_interval: 20000
source:
- entity_id: camera.test
model:
graph: /config/tensorflow/frozen_inference_graph.pb
categories:
- person
file_out:
- "/config/tmp/latest.jpg"
Has anyone experienced the same and may point me in the right direction?
I’m running HA in a Docker on my NAS with 2.4Ghz QuadCore and 16MB Ram, performance should not be an issue.
Thanks!
