Hi there,
Am busy setting up a USB SonyPlaystation cam, connected on my Pi 3 model B. I installed motion and that all goes well but when I found a reference to this article: https://www.raspberrypi.org/documentation/configuration/camera.md and executed this command: raspistill -v -o test.jpg, then I got this response:
mmal: Cannot read camera info, keeping the defaults for OV5647
raspistill Camera App v1.3.11
Time delay 5000, Raw no
Thumbnail enabled Yes, width 64, height 48, quality 35
Link to latest frame enabled no
Full resolution preview No
Capture method : Single capture
Preview Yes, Full screen Yes
Preview window 0,0,1024,768
Opacity 255
Sharpness 0, Contrast 0, Brightness 50
Saturation 0, ISO 0, Video Stabilisation No, Exposure compensation 0
Exposure Mode 'auto', AWB Mode 'auto', Image Effect 'none'
Flicker Avoid Mode 'off'
Metering Mode 'average', Colour Effect Enabled No with U = 128, V = 128
Rotation 0, hflip No, vflip No
ROI x 0.000000, y 0.000000, w 1.000000 h 1.000000
mmal: mmal_vc_component_create: failed to create component 'vc.ril.camera' (1:ENOMEM)
mmal: mmal_component_create_core: could not create component 'vc.ril.camera' (1)
mmal: Failed to create camera component
mmal: main: Failed to create camera component
mmal: Camera is not detected. Please check carefully the camera module is installed correctly
Seems like there is a mmal component that seems not to have been installed. Have also searched for a solution both on the forum and Google but found no answer. Also I have upgraded to the latest versions. Any suggestions?
Thanks,
Hans
