Camera snapshot and additional actions when input boolean is triggered
This blueprint takes a snapshot of a camera when an input boolean is turned on. You can add additional actions afterwards.
For example, you can send a notification to your phone using the variable {{ snapshot_file_path }} as the image URL.
blueprint:
  name: Camera snapshot and actions when input boolean is turned on
  description: >-
    Creates a snapshot and triggers a subsequent action when an input boolean is turned on
  domain: automation
  input:
    input_boolean:
      description: The sensor wich triggers the snapshot creation
      selector:
        entity:
          domain: input_boolean
    camera:
      description: The camera which creates the snapshot
      selector:
        entity:
          domain: camera
    delay:
      name: 'Snapshot Delay (Optional)'
      description: 'Wait before creating camera snapshot'
      default: 0.0
      selector:
        number:
          min: 0.0
          max: 60.0
          unit_of_measurement: seconds
          mode: slider
          step: 1.0
    additional_actions:
      description: >-
        Actions after taking snapshot. (Optional)
        Example: A notification using {{ snapshot_file_path }} as the image.
      default: []
      selector:
  source_url: https://community.home-assistant.io/t/camera-snapshot-and-additional-actions-when-input-boolean-is-triggered/313008
mode: restart
variables:
  input_boolean: !input 'input_boolean'
  input_boolean_name: '{{ states[input_boolean].name }}'
  camera: !input 'camera'
  delay: !input 'delay'
  snapshot_create_file_path: '/config/www/tmp/snapshot_{{ states[camera].object_id }}.jpg'
  snapshot_file_path: '{{ snapshot_create_file_path | replace(''/config/www'', ''/local'') }}'
  platform: state
  entity_id: !input 'input_boolean'
  to: 'on'
  - delay: '{{ delay }}'
  - service: camera.snapshot
    entity_id: !input 'camera'
      filename: '{{ snapshot_create_file_path }}'
  - choose:
    default: !input additional_actions
Based on this which was based on this blueprint. Thanks to vorion for the original blueprint.
I have been struglling to have the image on the message.
How its suposed to be placed?
action: notify.telegram_joao
message: Chegou correio!
title: CORREIO
image: >-
http://xxx.xxx.x.xxx:xxxx/local/tmp/snapshot_dahua_mediaprofile_channel1_mainstream.jpg
But its not working.
Please help.
Hey I was wondering is this up to date for 2024?
I like what you have going on.
Will this create a longer live feed if motion is detected?
Trying to find a way to get longer live feed on a conditional motion activated card.
Like to have jpg push to mobile too
