Hi there.
So I am using the eufy-ha-mqtt-bridge to bring binary sensors into Home Assistant and to view the latest image based on the last event in each camera.
This is all working fine, but I’d like to send the image from the last event in a telegram notification when someone rings my doorbell (not a doorbell camera, just a button in HA).
The last event image is coming from a camera entity camera.front_door_last_event
The image shown is the ‘entity_picture’. There is no live stream.
I’d like to just send that ‘entity_picture’ in the ‘notify.*****_tele’ service call or telegram_bot.send_photo.
I’ve tried the camera.snapshot service call, but I’m receiving this error:
Logger: homeassistant.components.camera
Source: components/camera/__init__.py:659
Integration: Camera ([documentation](https://www.home-assistant.io/integrations/camera), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+camera%22))
First occurred: 9:27:27 AM (87 occurrences)
Last logged: 4:12:10 PM
* Can't write /tmp/snapshot_camera.front_door_last_event.jpg, no access to path!
* Can't write /www/tmp/snapshot_camera.front_door_last_event.jpg, no access to path!
* Can't write /config/www/tmp/snapshot_camera.front_door_last_event.jpg, no access to path!
As you can see, I’ve tried a couple different combinations of file paths to no avail. I’ve manually created the tmp folder in each of those locations for testing.
So I can’t seem to save the image locally.
The other problem is that I can’t send a photo via telegram_bot.
For testing, I just put a .jpg image into those folders with the same file names and when I call
with
file: '/www/tmp/snapshot_camera.front_door_last_event.jpg'
target: #######omitted for privacy
caption: someone rang the doorbell
in the data section, I receive this error in the logs:
Logger: homeassistant.components.telegram_bot
Source: components/telegram_bot/__init__.py:795
Integration: Telegram bot (documentation, issues)
First occurred: 9:45:45 AM (16 occurrences)
Last logged: 4:23:49 PM
Can't send file with kwargs: {'file': '/www/tmp/snapshot_camera.front_door_last_event.jpg', 'caption': 'someone rang the doorbell'}
So I’m failing at both ends.
Anyone able to shed some light on my issues?
I’d really appreciate the help.
