I’m having a hard time generating a camera.snapshot for use in automations. I have the camera setup and working in HA. Both still and motion URL’s work as well. I also have the directory allowlisted… But calling the camera.snapshot service does not generate anything.
I was struggling with this for a minute. But it passes a configuration check when entered as the following. And not if the directory doesn’t exist or otherwise. Perhaps I’m not looking in the correct folder afterall.when connecting via smb which doesn’t have config/www. I think my confusion lies in there somewhere.
You should also see if a file (snapshot) is created via the file editor addon and/or visio studio code or others. besides your “configuration.yaml” file there must be a www folder with the snapshot in it…?
I also do not know if you “just started” and just created a www folder yourself. if so you must restart homeassistant or you cant use it.
Strange. No www folder at all on the same level as config.yaml via file editor. The tmp/snapshots directory is there though as I created it. Is there some special assignation to the www folder? Sorry, I’m not aware of the history of that folder. This is an install that has been running for about a year and a bit (though updated to current versions).
