Same for me. Works in the app but it won’t show on my google nest. As you described, it just shows the default media player. I saw an error in the log, but I wasn’t able to understand where the issue may be from it:
Error executing service: <ServiceCall media_player.play_media (c:01H3Q42YKBNNTC5A594RMM5W0C): entity_id=['media_player.kitchen_display'], extra=, media_type=application/vnd.apple.mpegurl, media_id=http://172.26.0.2:8123/api/hls/06fd1f9e24af96644554ce5f7da84e566605199a8f2c6360f5dd3d9fd831fe40/master_playlist.m3u8>
File "/usr/src/homeassistant/homeassistant/core.py", line 1928, in catch_exceptions
await coro_or_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1950, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 226, in handle_service
await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 811, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1034, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 851, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/cast/media_player.py", line 739, in async_play_media
await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.11/site-packages/pychromecast/quick_play.py", line 78, in quick_play
controller.quick_play(**data)
File "/usr/local/lib/python3.11/site-packages/pychromecast/controllers/media.py", line 547, in quick_play
raise PyChromecastError() # pylint: disable=broad-exception-raised
pychromecast.error.PyChromecastError
I’m running 2023.6 and the reolink is up to date too.
As an aside, the visitor button press is not being picked up either, but the person detection is. I’m hoping that this is an issue that will probably be fixed relatively quickly. I just wanted to give my experience with this integration so far.
