Hi all, was just wondering if someone could help. Since upgrading Frigate to V13, the Frigate card on the front-end gives the following error for cameras not running, instead of giving the typical ‘No frames have been received, check error logs’ (just like it does in the Frigate UI).
Does anyone know how to solve this? Not all of our cameras are running when at home, hence why I would normally get the ‘No frames have been received…’ error in the Frigate card, but with this new error, the card can’t be used until I close the HA app or browser session.
I receive the error across all browsers and the app. Frigate is running in an LXC, and HA in a VM in Proxmox. As mentioned, I had no issues before upgrading Frigate, the proxy add-on and the Lovelace card…
same issue here. Before upgrade frigate card and frigate software, the camera works well. But after the upgrade is have the same issue. Sometimes i got the message comera unavailable and sometimes no frames received.
Same here, using 13 Beta and now switched to 13.
SOLUTION go to settings → integration and there you will see the beta integration isn’t working. Add integration and the new integration will be automatically made.
Yes, please explain in more detail because I can’t see where you mean. Also, are describing this for the add-on, or docker install (I’m running Fridays in docker, and use the Frigate proxy in HA).
