Camera view not updating HA Dashboard / Apple Home
Good morning,
Sorry if this is not the right category, I’ve been searching the forums but not had any luck so far.
I just moved from Homebridge to Home Assistant and the experience so far is really positive, I’ve now set up both the Ring and Blink integration and have successfully logged in on both, the feed is there on the HA dash and on Apple Home.
Blink:
  • When selecting the live view on HA dash where the still doesn’t update/turn into live feed or Apple Home the view keeps loading until the error text “This camera is not responding.” appears.
Ring:
  • Same issue with the live feed - camera view only updates to when motion is detected or the doorbell is rung.
On Homebridge I had functioning live views on both the dashboard and Apple Home.
Integrations used:
Ring - Home Assistant (home-assistant.io)
Blink - Home Assistant (home-assistant.io)
Addons tested:
jeroenterheerdt/ring-hassio: A Home Assistant add-on for live streaming from Ring devices. (keeps crashing - s6-overlay-suexec: fatal: can only run as pid 1)
Video Streaming · tsightler/ring-mqtt Wiki
I hope someone can help me with this, thanks in advance!
The addons are missing links as I’m limited to two links max.
