Camera Xiaomi Mi Home 360 - how?
Did anyone managed to get rid of the delay?
we have same camera model and firmware. still go into idle mode, but i have noticed that little preview changes sometimes.
guys, forget this cameraā€¦ It doesnā€™t have integration with HA for now ā€¦
a lot of work seems to have been put into this integration, as things barely work at times, can someone update the integration please so it provides at least some partial functionality? These cameras are cheap and widespread, they work ok-ish with the cloud app once you know how to avoid jamming them by changing videos you watch on the card very often, I already have 7 of these cameras :frowning: I hope I donā€™t have to replace them or give up on the dream of seeing the last motion detected at least as a photo in HA.
Sadly I came to the same conclusion and ended up going for a Foscam (R2M) instead, which works well with the native integration in Home Assistant (both to view the video stream and control the PTZ).
hey mate , I got my cameras to show up that way but I have that 15 sec delay , how did you fix it ? Iā€™m not that good with yaml and I donā€™t know where and how to add that code to stop the delay ā€¦ could you please help me ?
cheers mate
Guys any PTZ control for the camera? what about audio stream?
Seems like the problem is coming from the camera is sending its streaming through cloud. HA blocks access to the initially authorized https access with key authorisation, since the new one is different from the first streaming. mi cloud is updating its streaming data (key id) regularly, thatā€™s why itā€™s blocked by HA and just keep looping the initial streaming. No solutions available at this moment. The best way is connecting the camera streaming directly from camera to HA server in intranet without going through external web sphere, seems likeā€¦
I think problem is that the camera does not provide a live streaming entityā€¦ we use the MOTION SENSOR entity, which is not properly to be usedā€¦ because it captures a short video and thatĀ“s itā€¦ it shows this video in a loop.
There was a solution, but you have to downgrade the FW to an older one, but once we have a particular FW, u r not able do downgrade itā€¦
in other wordsā€¦ the camera is really nice, very responsive, and also the qualityā€¦but for now it cannot be used with HA
Do you know of a similar alternative? Maybe do Eufy cameras work?
Guys any PTZ control for the camera over HA?
I have a TP-LINK Tapo C210 camera, which I integrated easily with HA.
I do not receive the last picture anymore since a few months. Anyobdy has the same problem, and potentially a solution? Iā€™m now on firmware 4.3.7. As told above, it was only the picture of the last motion, but that was at least a bit. Now the ā€œmotionā€ picture is just blank.
Is it possible to take snapshot ?
Any News here?
I Setup the Cam, get a Picture and Stream after the Setup. But after some Time, the Stream freezes and wonā€™t start anymore.
i found out xiaomi lets you save the footage in a nas, and you can use homeassistant as a nas. i got the camera to send footage to my homeassistant and save it in /media. i dont know how to play it in the dashboard. can you help me?
How frequently does the media file get updated? Iā€™m trying to understand if this storage can be used for Live streaming or not?
Have you tried opening that file remotely via VLC or something?
Iā€™m trying to install Xiaomi miot in home assistant superviser version as I tried before with a docker version, and I still have an error when using the link from github. any idea ?
i have an error on sream
Logger: custom_components.xiaomi_miot.camera
Source: custom_components/xiaomi_miot/camera.py:372
integration: Xiaomi Miot Auto (documentation, issues)
First occurred: 13:58:22 (308 occurrences)
Last logged: 14:25:15
Camera Masina(chuangmi.camera.021a04): Get miot camera stream error from cloud: {'did': '1028622485', 'miid': 0, 'siid': 7, 'aiid': 1, 'code': 0, 'out': ['https://de15.livestreaming.io.mi.com/hlstranscoder/GCA5NjlhZDQ5MDE1NDA0YzEwOWEwYzE2Y2FmYjZiZGQ5MhgKX191bnVzZWRfXwA_H265transH264/playlist.m3u8'], 'exe_time': 0, 'withLatency': 0}
Camera Masina(chuangmi.camera.021a04): Get miot camera stream error from cloud: {'did': '1028622485', 'miid': 0, 'siid': 7, 'aiid': 1, 'code': 0, 'out': ['https://de16.livestreaming.io.mi.com/hlstranscoder/GCAwNmNhN2U2MDUyMjA0MjRkYmI2NjgyMGMwMDg2YzI3NBgKX191bnVzZWRfXwA_H265transH264/playlist.m3u8'], 'exe_time': 0, 'withLatency': 0}
Camera Masina(chuangmi.camera.021a04): Get miot camera stream error from cloud: {'did': '1028622485', 'miid': 0, 'siid': 7, 'aiid': 1, 'code': 0, 'out': ['https://de04.livestreaming.io.mi.com/hlstranscoder/GCBmYWE0MzcyMWZmZWM0Y2NiYjA2YmFjNzAzNGViODg1ORgKX191bnVzZWRfXwA_H265transH264/playlist.m3u8'], 'exe_time': 0, 'withLatency': 0}
Camera Masina(chuangmi.camera.021a04): Get miot camera stream error from cloud: {'did': '1028622485', 'miid': 0, 'siid': 7, 'aiid': 1, 'code': -704220025, 'exe_time': 0, 'withLatency': 0}
iā€™m getting the same error. i hope this can be resolved.
