Can I create an automation that is triggered by a wemo switch button press that will suspend another automation until that device is manually or automatically turned off?
Example… I have a small space heater in my old houses bathroom. I like to run it in the morning while in the shower. But, I have an automation that looks at the temperature in the bathroom and if warm enough it turns off the heater, overriding the manual activation. I could set times that he automatic control will not be active, but that is not good for our house since others may shower at different times of the day.
homeassistant.turn_off works for many domains, basically any domain that has a turn_off service. You could use it for lights, switches, automations, etc. This can be very helpful if you want to turn off or on a mixed group (e.g. a group.living_room that has lights and switches). Obviously, you can only use automation.turn_off to turn off automations.
As @Dolores says, it’s like a catch all for turn_on and turn_off (and possibly toggle). I find it easier to just use it for everything I can and then only component specific services (which are usually one offs) use their own services. Makes it quicker for me anyway
This is good to know. I love this forum, every question is a learning experience. I am also amazed at how much can be accomplished on an RPi2.
I have a large number of automatons, some are fairly complex conditional automations that are supplemented by some fairly simple automatons on the same device or group. I am to the point that I am afraid that I am going to have to get much more complex to properly do what I want to do.
For example this one heater needs to do the following:
turn on between 5:55 and 7:00 am, if it is below 55 outside. May be manually turned off at an earlier time. Good shower time
turn on when the room is below 65 based on an mqtt sensor in the room
turn off when the room is above 65
turn off after 1.5 hours regardless of the situation
turn on and run if turned on manually, until 1.5 hours have passed or until turned off manually.
I have ended up in a state where the first automation fires and the second and third interrupt it. I think I have it fixed thanks to the above tips. I would like to be able to detect a button press on the wemo switch and override all but number 4. So, I need to differentiate between a button press and the automatons number 2 & 3 to make this happen. Will have to dig deeper. I am beginning to wonder if one giant automation might be the answer with or’s and and’s.
You should be able to do this with five automations. It’s a lot of them but I don’t think that it will be too ugly.
a. Matches automation 1 as you described, with the addition of turning on an input boolean. (e.g. input_boolean.shower_time)
b. Matches automation 2 as you described, with the addition of turning on an input boolean (e.g. input_boolean.auto_heat ). Add a small delay before turning on this input_boolean.
c. Matches three as you described, but checks if input_boolean.shower_time is off. and if input_boolean.auto_heat is on. If true, turn off the heater.
d. Matches automation 4 as you described, using the state trigger with a “for 90 minutes” specification. This will also handle automation 5.
e. New automation: On a state change of the wemo switch, turn off input_boolean.auto_heat. If a person did this, it will effectively disable automation c. The next time the heat automatically kicks in, (based on automation b), it will re-enable the temperature based control.
Perhaps someone else has a recommendation for how to clean this up a bit, but I think it will be clean (except for perhaps automation e).
First one triggers whenever the heater is switched on, action is delay 90 minutes and switch off. That takes care of 4 and 5.
Second one has a two time triggers and a template trigger, time triggers are 5.55 and 7am, template is temperature. Action is a service template, if 5.55 or below 65 degrees switch on, if 7am or above 65 degrees switch off.
I have not ever used input_boolean. I will have to look into this. I may comment out all of my existing autos for this device and ask for opinions… Would that be to much to ask for?
I will have to ponder on this… I currently have 7 autos to come very close to what I wanted to do… Will have to read again on templates and look for some examples.
It takes a seperate system from the Hassio install? That is what I have gotten in the past anyway. Will look deeper, some of these autos are a PITA. I do like to run with no external dependencies, such as other systems or cloud apps or services.
Thanks for your time, I know I have told you that before! I am up to around 30 autos and am getting a feel for all of it except templates and still trying to figure out when to use service calls. I really like Hassio, I can see at some point it might be good to get away from the closed environment, but is has been good for learning.
I have also enjoyed building my own Wemos based sensors and working with the Sonoff’s and Tasmota.
Node-Red or AppDaemon will run on the same hardware as ‘add-ons’. Just like the other add-ons you probably rely on, it wouldn’t really be any more risk than the current hassio you are using.
Ok, so I have created an input_boolean starting with the state off. I am using it to index the various automatons and it seems to work well. But, I have one problem… how do I set it’s state to on when I turn the heater on in the UI or when someone presses the button on the wemo?
I do not think I can do it with a state from off to on in a simple state checker because some of the automations may try to change it back based on condition… Maybe I am overthinking it and should use a state change. Would that actually work?
This is what I now have for my set of automations…
# Automations for Bathroom Heat #
- id: "Bathroom heat on at 05:55 weekdays if cold"
alias: 'Bathroom heat on at 05:55 weekdays if cold'
- platform: time
at: '05:55:00'
condition:
condition: and
conditions:
- condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
- condition: numeric_state
entity_id: sensor.pws_temp_f
below: 55
- service: switch.turn_on
entity_id: switch.bathroom_heater
- service: homeassistant.turn_off
entity_id: automation.bathroom_heat_on_timer_room_warm
entity_id: input_boolean.notify_bathroom_heat
- id: "Bathroom heat off at 07:00"
alias: 'Bathroom heat off at 07:00'
- platform: time
at: '07:00:00'
- service: switch.turn_off
- service: homeassistant.turn_on
- service: input_boolean.turn_off
- id: "Bathroom heat on for to long"
alias: 'Bathroom heat on for to long'
platform: state
to: 'on'
for:
hours: 1
minutes: 30
- id: "Bathroom heat on timer room cold"
alias: 'Bathroom heat on timer room cold'
- platform: time
minutes: '/5'
seconds: '00'
# Trigger every X minutes, "/" causes repeating trigger
- platform: numeric_state
entity_id: sensor.temperature3
below: '63'
for:
minutes: 2
# Trigger based on WU temp below X and has been for Y minutes
condition:
condition: and
conditions:
below: '63'
# Verify WU temp below X
- condition: state
state: 'off'
- condition: state
state: 'off'
# Verify switch is really off
# - service: notify.sms_matt
# data:
# title: "Warning"
# message: "Bathroom heat on"
# Set switch to correct state "ON"
- id: "Bathroom heat off timer room warm"
alias: 'Bathroom heat on timer room warm'
- platform: time
minutes: '/5'
seconds: '00'
above: '63'
for:
minutes: 2
condition:
condition: and
conditions:
above: '63'
- condition: state
state: 'on'
- condition: state
state: 'off'
The more I study this the more I realize that all I have to do is to change the boolean state when it is manually turned on…
