Hi All,
I am using the HACS Climate Template, basically everything is working perfectly except I cannot turn off the AC due to the Daikin VRV data structure.
Basically HA has 1 entity for mode, that include “cool”, “dry”, “fan”, “off”, etc.
My Daikin VRV (via BACNET) has:
- 1 x entity for modes (“cool”, “dry”, “fan”)
- 1 x entity for on/off
Hence it doesnt map to the HA data model very well, by using the climate template so far everything is working perfectly except I cannot turn the AC on or off… and I am not sure within the “set_hav_mode” service I can target different entities based on the contents.
Below I tried stacking the “select_option” but then I lost control of all modes.
Does anyone know how I could somehow force the “off” mode to a different entity?
set_hvac_mode:
- service: select.select_option
entity_id: select.bacnet_airconmodecommand_020
option: "{% if hvac_mode == 'cool' %}1{% elif hvac_mode == 'fan_only' %}3{% elif hvac_mode == 'dry' %}5{% endif %}"
entity_id: switch.bacnet_startstopcommand_020
option: "{% if hvac_mode == 'off' %}0{% else %}1{% endif %}"
In terms of reading in the state (which is a seperate set of entities) I was able to create below that works perfectly combining the 2 entities.
`hvac_mode_template: "
{% if states('binary_sensor.bacnet_startstopstatus_020') == 'off' %}
off
{% elif states('sensor.bacnet_airconmodestatus_020') == '1' %}
cool
{% elif states('sensor.bacnet_airconmodestatus_020') == '3'%}
fan
{% elif states('sensor.bacnet_airconmodestatus_020') == '5'%}
dry
{% else %}
off
{% endif %}"`
