Hi. I have Hassio installed on a Raspberry Pi 3. I also have an Asus router. I set up my router as an Open VPN server. I have a Macbook pro that I’m using as a VPN client that I use at work to access my home network. I know the VPN works because I can access my Blue Iris setup at home. I can also access Home Assistant even without the Duck DNS setup.
However, I can’t figure out why I can’t access the Configurator. When I try to connect, I get this message: “Policy not fulfilled”.
I know I can set up Duck DNS but I’d rather access the Configurator through my VPN. I don’t want to open too many ports on my router.
Any ideas?
