I’ve search but can’t find the answer to this. Can the IMAP integration password be changed?
I have an existing sensor, and just need to change my password on the IMAP account. But under both Device and Entity, I cannot find a field to just change the password.
I don’t have the IMAP integration, but as I understand it, the integration is just monitoring an IMAP server, and the password is on the server.
Did you enter a password when you installed the IMAP integration? I have a couple of integrations that install this way. If the password on the server changes, I just delete the integration and reinstall it where the setup will ask for a password.
Yeahhhhh I was wondering about that. So it’s probably stored in the server’s keychain. I’ll try to just change the password and see if I get prompted, or have to recreate.
To change the password, you need to first update the password on the IMAP account.
Then, you can go into the IMAP Integration, and it should show a red banner indicating the username or password is incorrect. Hit the “Add Entry” and it will ask you for a new password.
