I want a smart plug compatible with HA that supports ‘staying in power off mode’ after a power cut.
I purchased a Tapo P110 which does this but it will not connect to HA.
Many thanks.
Many thanks.
Any number of plugs do that. Do you have any requirements?
I love these KAUF Power Monitoring Smart Plug with ESPHome, Compatible with Tasmota, Made for Home Assistant - Amazon.com and these Smart Plug Work with Alexa and Google Home Nooie,Smart Alexa Plug Mini Bluetooth Smart Life&Tuya, Smart Outlet Plug Voice Control, WiFi Plug, Enchufe Inteligente Schedule Timer, 2.4Ghz Only, 4-Pack: Amazon.com: Tools & Home Improvement
Literally everything that can be owned and allows full local control like ESPHome based devices
Also recommend ESPhome / Tasmota, but plugs are notoriously difficult to shop for because they’re ordinarily sealed and difficult to flash. Out of all my Tasmota plugs, I had bad luck with the KAUF plug (two of four failed during the return period) and all four of my SwitchBot plugs (flashed OTA) died in under a year due to poor electronics
Right now I’m using the Athom v3 plug (ships pre-flashed) and the Wyze outdoor plug (can be opened and flashed serially), both esp32-based, with good success.
The Tapo p110 is supported by HA according to the tp link integration.
Thanks all, useful info which I will follow up today. I checked the KAUF plug but not available on Amazon in the UK, will keep looking though.
FYI BTW the Tapo P110 is not Discovered by HA and attempting to add it manually (with the ip address)results in a ‘device not found’ error.
Or the V2 which is esp82xx based and less than $10 now
In case you missed it, you need to follow the prerequisites in order to add the smart plug to HA.
I figure it’s worth a try before trashing the plug and buying another.
Thanks but I have added it to the Tapo app as described in the pre requisites
Hmm, maybe have a look at the troubleshooting & reported connection solutions sections then? The kasa tool might look intimidating, but it seems quite simple to install and only involves a 1-line command to connect.
Having a good topic title is essential. It should summarise your post so that without even opening it people can have a good idea of what it’s about.
A good topic generally:
For example:
If you’re having a problem writing a good topic title, leave it for last - once you’ve written the whole question, it might be easier to write a summary title for it.
