Hi, my system is rebooting without any reason (for me).
I tried to disconnect the zigbee and z-wave dongle without succes.
I power the dongles wit a powers USB-hub, also without succes.
I can’t find something in the log’s. This is my log.1 file (the latest part):
2025-03-23 22:37:21.643 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-03-23 22:37:21.670 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration afvalwijzer which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-03-23 22:37:21.691 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration tado which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-03-23 22:37:26.347 WARNING (MainThread) [homeassistant.helpers.translation] Failed to load integration for translation: Integration 'resources' not found.
2025-03-23 22:37:27.052 INFO (MainThread) [homeassistant.setup] Setup of domain logger took 0.71 seconds
2025-03-23 22:37:27.052 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.69 seconds
2025-03-23 22:37:27.052 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.71 seconds
2025-03-23 22:37:27.053 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2025-03-23 22:37:27.054 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.00 seconds
2025-03-23 22:37:27.054 INFO (MainThread) [homeassistant.setup] Setting up network
2025-03-23 22:37:27.061 INFO (MainThread) [homeassistant.setup] Setup of domain network took 0.01 seconds
2025-03-23 22:37:27.063 INFO (MainThread) [homeassistant.bootstrap] Setting up frontend: {'frontend'}
2025-03-23 22:37:27.063 INFO (MainThread) [homeassistant.setup] Setting up api
2025-03-23 22:37:27.068 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.00 seconds
2025-03-23 22:37:27.069 INFO (MainThread) [homeassistant.setup] Setting up auth
2025-03-23 22:37:27.072 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.00 seconds
2025-03-23 22:37:27.072 INFO (MainThread) [homeassistant.setup] Setting up config
2025-03-23 22:37:27.084 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.01 seconds
2025-03-23 22:37:27.085 INFO (MainThread) [homeassistant.setup] Setting up device_automation
2025-03-23 22:37:27.086 INFO (MainThread) [homeassistant.setup] Setup of domain device_automation took 0.00 seconds
2025-03-23 22:37:27.086 INFO (MainThread) [homeassistant.setup] Setting up diagnostics
2025-03-23 22:37:27.089 INFO (MainThread) [homeassistant.setup] Setup of domain diagnostics took 0.00 seconds
2025-03-23 22:37:27.090 INFO (MainThread) [homeassistant.setup] Setting up file_upload
2025-03-23 22:37:27.091 INFO (MainThread) [homeassistant.setup] Setup of domain file_upload took 0.00 seconds
2025-03-23 22:37:27.092 INFO (MainThread) [homeassistant.setup] Setting up image_upload
2025-03-23 22:37:27.094 INFO (MainThread) [homeassistant.setup] Setup of domain image_upload took 0.00 seconds
2025-03-23 22:37:27.095 INFO (MainThread) [homeassistant.setup] Setting up person
2025-03-23 22:37:27.097 INFO (MainThread) [homeassistant.setup] Setting up repairs
2025-03-23 22:37:27.099 INFO (MainThread) [homeassistant.setup] Setup of domain repairs took 0.00 seconds
2025-03-23 22:37:27.100 INFO (MainThread) [homeassistant.setup] Setting up search
2025-03-23 22:37:27.100 INFO (MainThread) [homeassistant.setup] Setup of domain search took 0.00 seconds
2025-03-23 22:37:27.104 INFO (MainThread) [homeassistant.setup] Setup of domain person took 0.01 seconds
2025-03-23 22:37:27.104 INFO (MainThread) [homeassistant.setup] Setting up onboarding
2025-03-23 22:37:27.105 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 0.00 seconds
2025-03-23 22:37:27.106 INFO (MainThread) [homeassistant.setup] Setting up lovelace
2025-03-23 22:37:27.112 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.01 seconds
2025-03-23 22:37:27.113 INFO (MainThread) [homeassistant.setup] Setting up frontend
2025-03-23 22:37:27.139 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.03 seconds
2025-03-23 22:37:27.140 INFO (MainThread) [homeassistant.bootstrap] Setting up recorder: {'recorder'}
2025-03-23 22:37:27.140 INFO (MainThread) [homeassistant.setup] Setting up recorder
2025-03-23 22:37:27.153 INFO (MainThread) [homeassistant.components.http] Now listening on port 8123
2025-03-23 22:37:27.155 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.02 seconds
2025-03-23 22:37:27.258 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2025-03-23 22:37:27.983 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=1051 from 2025-03-23 21:18:47.736962)
2025-03-23 22:37:28.086 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.95 seconds
2025-03-23 22:37:28.087 INFO (MainThread) [homeassistant.bootstrap] Setting up zeroconf: {'zeroconf'}
2025-03-23 22:37:28.088 INFO (MainThread) [homeassistant.setup] Setting up zeroconf
2025-03-23 22:37:28.200 INFO (MainThread) [homeassistant.components.zeroconf] Starting Zeroconf broadcast
2025-03-23 22:37:28.205 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 0.12 seconds
2025-03-23 22:37:28.205 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 1: {'hassio', 'bluetooth', 'usb', 'dhcp', 'cloud', 'ssdp'}
2025-03-23 22:37:28.207 INFO (MainThread) [homeassistant.setup] Setting up hassio
2025-03-23 22:37:28.780 INFO (MainThread) [homeassistant.setup] Setting up webhook
2025-03-23 22:37:28.782 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.00 seconds
2025-03-23 22:37:29.018 INFO (MainThread) [homeassistant.setup] Setup of domain hassio took 0.81 seconds
2025-03-23 22:37:29.156 INFO (MainThread) [homeassistant.setup] Setting up usb
2025-03-23 22:37:29.157 INFO (MainThread) [homeassistant.setup] Setup of domain usb took 0.00 seconds
2025-03-23 22:37:29.305 INFO (MainThread) [homeassistant.setup] Setting up update
2025-03-23 22:37:29.316 INFO (MainThread) [homeassistant.setup] Setup of domain update took 0.01 seconds
2025-03-23 22:37:29.323 INFO (MainThread) [homeassistant.components.update] Setting up hassio.update
2025-03-23 22:37:36.738 INFO (MainThread) [homeassistant.setup] Setting up dhcp
2025-03-23 22:37:36.739 INFO (MainThread) [homeassistant.setup] Setup of domain dhcp took 0.00 seconds
2025-03-23 22:37:39.594 INFO (MainThread) [homeassistant.setup] Setting up cloud
2025-03-23 22:37:39.604 INFO (MainThread) [homeassistant.setup] Setting up ffmpeg
2025-03-23 22:37:39.605 INFO (MainThread) [homeassistant.setup] Setup of domain ffmpeg took 0.00 seconds
2025-03-23 22:37:39.607 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 0.01 seconds
2025-03-23 22:37:39.725 INFO (MainThread) [homeassistant.setup] Setting up ssdp
2025-03-23 22:37:39.734 INFO (MainThread) [homeassistant.setup] Setup of domain ssdp took 0.01 seconds
2025-03-23 22:37:40.203 INFO (MainThread) [homeassistant.setup] Setting up bluetooth
2025-03-23 22:37:40.260 INFO (MainThread) [homeassistant.setup] Setting up binary_sensor
2025-03-23 22:37:40.263 INFO (MainThread) [homeassistant.setup] Setup of domain binary_sensor took 0.00 seconds
2025-03-23 22:37:40.264 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up hassio.binary_sensor
2025-03-23 22:37:40.352 INFO (MainThread) [homeassistant.setup] Setup of domain bluetooth took 0.15 seconds
2025-03-23 22:37:40.443 INFO (MainThread) [homeassistant.setup] Setting up sensor
2025-03-23 22:37:40.445 INFO (MainThread) [homeassistant.components.sensor] Setting up serial.sensor
2025-03-23 22:37:40.447 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 0.00 seconds
2025-03-23 22:37:40.447 INFO (MainThread) [homeassistant.components.sensor] Setting up hassio.sensor
2025-03-23 22:53:14.743 INFO (MainThread) [homeassistant.components.analytics] Submitted analytics to Home Assistant servers. Information submitted includes {'uuid': '8dd467077c0e43bdb40d4a8123865e79', 'version': '2025.3.4', 'installation_type': 'Home Assistant OS', 'supervisor': {'healthy': True, 'supported': True, 'arch': 'aarch64'}, 'operating_system': {'board': 'rpi4-64', 'version': '15.0'}, 'certificate': True, 'integrations': ['derivative', 'homeassistant', 'sensor', 'systemmonitor', 'sma', 'automation', 'ping', 'bluetooth', 'openweathermap', 'zone', 'http', 'api', 'logger', 'met', 'mqtt', 'cast', 'homewizard', 'input_datetime', 'energy', 'group', 'min_max', 'version', 'default_config', 'forecast_solar', 'adguard', 'input_boolean', 'script', 'zwave_js', 'utility_meter', 'braviatv', 'dnsip', 'dlna_dmr', 'google', 'tts', 'dhcp', 'ssdp', 'rpi_power', 'wyoming', 'hassio', 'scene', 'usb', 'cert_expiry', 'androidtv_remote', 'binary_sensor', 'speedtestdotnet', 'proximity', 'uptime', 'person', 'sql', 'input_number', 'mobile_app', 'timer', 'sun', 'co2signal', 'template'], 'custom_integrations': [{'domain': 'tado', 'version': <AwesomeVersion BuildVer '140761'>}, {'domain': 'afvalwijzer', 'version': <AwesomeVersion CalVer '2025.01.01'>}, {'domain': 'hacs', 'version': <AwesomeVersion SemVer '2.0.5'>}], 'addons': [{'slug': 'core_ssh', 'protected': True, 'version': '9.16.0', 'auto_update': True}, {'slug': 'core_configurator', 'protected': True, 'version': '5.8.0', 'auto_update': True}, {'slug': 'core_samba', 'protected': True, 'version': '12.5.0', 'auto_update': True}, {'slug': 'cebe7a76_hassio_google_drive_backup', 'protected': True, 'version': '0.112.1', 'auto_update': True}, {'slug': 'a0d7b954_wireguard', 'protected': True, 'version': '0.11.0', 'auto_update': True}, {'slug': 'a0d7b954_adguard', 'protected': True, 'version': '5.2.6', 'auto_update': True}, {'slug': 'core_letsencrypt', 'protected': True, 'version': '5.4.3', 'auto_update': True}, {'slug': 'a0d7b954_vscode', 'protected': True, 'version': '5.18.3', 'auto_update': True}, {'slug': 'core_mosquitto', 'protected': True, 'version': '6.5.0', 'auto_update': True}, {'slug': 'a0d7b954_zwavejs2mqtt', 'protected': True, 'version': '3.24.0', 'auto_update': True}, {'slug': 'a0d7b954_glances', 'protected': True, 'version': '0.21.1', 'auto_update': True}, {'slug': '5ecb52bc_increase_swap_addon', 'protected': True, 'version': '1.1.3', 'auto_update': True}, {'slug': 'core_duckdns', 'protected': True, 'version': '1.18.0', 'auto_update': True}, {'slug': 'core_dnsmasq', 'protected': True, 'version': '1.8.1', 'auto_update': True}, {'slug': '45df7312_zigbee2mqtt', 'protected': True, 'version': '2.1.3-1', 'auto_update': True}, {'slug': 'core_speech-to-phrase', 'protected': True, 'version': '1.3.0', 'auto_update': False}], 'energy': {'configured': True}, 'recorder': {'engine': 'sqlite', 'version': <AwesomeVersion SimpleVer '3.48.0'>}, 'state_count': 847, 'automation_count': 132, 'integration_count': 55, 'addon_count': 16, 'user_count': 2}
2025-03-23 23:00:00.486 INFO (MainThread) [homeassistant.helpers.script.trigger_update_coordinator] Trigger Update Coordinator: Executing step call service
2025-03-23 23:00:00.488 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'dict object' has no attribute 'cloud_coverage' when rendering '{{ daily['weather.huis'].forecast[0].cloud_coverage }}'
2025-03-23 23:00:00.489 INFO (MainThread) [homeassistant.components.zwave_js] Refreshing primary value Value(value_id='9-50-2-value-66561') for sensor.in_wall_dual_relay_switch_module_2x1_5kw_with_power_meter_electric_consumption_v_2, state update may be delayed for devices on battery
2025-03-23 23:00:00.529 INFO (MainThread) [homeassistant.components.zwave_js] Refreshing primary value Value(value_id='9-50-2-value-66817') for sensor.in_wall_dual_relay_switch_module_2x1_5kw_with_power_meter_electric_consumption_a_2, state update may be delayed for devices on battery
2025-03-23 23:00:00.574 INFO (MainThread) [homeassistant.components.zwave_js] Refreshing primary value Value(value_id='9-50-2-value-67073') for sensor.in_wall_dual_relay_switch_module_2x1_5kw_with_power_meter_electric_consumption_power_factor_2, state update may be delayed for devices on battery
2025-03-23 23:00:00.676 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved (None)
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 635, in state
numerical_value = int(value)
ValueError: invalid literal for int() with base 10: ''
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 638, in state
numerical_value = float(value)
ValueError: could not convert string to float: ''
File "/usr/src/homeassistant/homeassistant/components/template/coordinator.py", line 117, in _handle_triggered_with_script
self._execute_update(run_variables, context)
File "/usr/src/homeassistant/homeassistant/components/template/coordinator.py", line 141, in _execute_update
self.async_set_updated_data(
{"run_variables": run_variables, "context": context}
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 515, in async_set_updated_data
self.async_update_listeners()
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 178, in async_update_listeners
update_callback()
File "/usr/src/homeassistant/homeassistant/components/template/trigger_entity.py", line 59, in _handle_coordinator_update
self.async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1023, in async_write_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1148, in _async_write_ha_state
self.__async_calculate_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1085, in __async_calculate_state
state = self._stringify_state(available)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1029, in _stringify_state
if (state := self.state) is None:
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 642, in state
raise ValueError(
...<5 lines>...
) from err
ValueError: Sensor sensor.openweathermap_forecast_cloud_coverage_3 has device class 'None', state class 'None' unit '%' and suggested precision 'None' thus indicating it has a numeric value; however, it has the non-numeric value: '' (<class 'str'>)
2025-03-23 23:00:00.690 INFO (MainThread) [homeassistant.components.zwave_js] Refreshing primary value Value(value_id='9-50-2-value-66049') for sensor.in_wall_dual_relay_switch_module_2x1_5kw_with_power_meter_electric_consumption_w_2, state update may be delayed for devices on battery
2025-03-23 23:00:01.211 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.25,"licht":34,"regen":1022,"wind":0.15}
2025-03-23 23:00:02.214 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.25,"licht":35,"regen":1022,"wind":0.15}
2025-03-23 23:00:03.218 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.19,"licht":35,"regen":1022,"wind":0.15}
2025-03-23 23:00:04.225 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.19,"licht":35,"regen":1022,"wind":0.15}
2025-03-23 23:00:05.229 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.19,"licht":35,"regen":1022,"wind":0.15}
2025-03-23 23:00:06.232 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.19,"licht":35,"regen":1022,"wind":0.30}
2025-03-23 23:00:07.235 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.19,"licht":35,"regen":1022,"wind":0.15}
2025-03-23 23:00:08.239 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.19,"licht":35,"regen":1022,"wind":0.15}
2025-03-23 23:00:09.242 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.19,"licht":35,"regen":1022,"wind":0.15}
2025-03-23 23:00:10.246 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.19,"licht":35,"regen":1022,"wind":0.15}
2025-03-23 23:00:11.257 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.19,"licht":35,"regen":1023,"wind":0.30}
2025-03-23 23:00:12.854 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.25,"licht":35,"regen":1022,"wind":0.15}
2025-03-23 23:00:13.526 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.19,"licht":35,"regen":1022,"wind":0.15}
2025-03-23 23:00:14.263 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.19,"licht":35,"regen":1022,"wind":0.15}
2025-03-23 23:00:15.267 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.19,"licht":35,"regen":1022,"wind":0.15}
2025-03-23 23:00:16.270 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.25,"licht":35,"regen":1022,"wind":0.15}
2025-03-23 23:00:17.274 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.25,"licht":35,"regen":1022,"wind":0.15}
2025-03-23 23:00:18.281 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.31,"licht":35,"regen":1022,"wind":0.30}
2025-03-23 23:00:19.284 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.25,"licht":35,"regen":1023,"wind":0.15}
2025-03-23 23:00:20.288 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.19,"licht":35,"regen":1022,"wind":0.15}
2025-03-23 23:00:21.291 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.25,"licht":34,"regen":1022,"wind":0.15}
2025-03-23 23:00:22.295 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.19,"licht":35,"regen":1022,"wind":0.15}
2025-03-23 23:00:23.298 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.25,"licht":35,"regen":1022,"wind":0.15}
2025-03-23 23:00:24.301 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.25,"licht":35,"regen":1022,"wind":0.15}
2025-03-23 23:00:25.305 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.25,"licht":35,"regen":1022,"wind":0.15}
2025-03-23 23:00:26.312 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.25,"licht":35,"regen":1022,"wind":0.15}
2025-03-23 23:00:27.315 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.25,"licht":35,"regen":1022,"wind":0.30}
2025-03-23 23:00:28.319 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.25,"licht":35,"regen":1023,"wind":0.30}
2025-03-23 23:00:29.322 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.25,"licht":35,"regen":1023,"wind":0.15}
2025-03-23 23:00:30.326 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.19,"licht":35,"regen":1022,"wind":0.15}
2025-03-23 23:00:31.329 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.19,"licht":34,"regen":1022,"wind":0.15}
2025-03-23 23:00:32.332 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.19,"licht":34,"regen":1022,"wind":0.15}
2025-03-23 23:00:33.336 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.25,"licht":35,"regen":1022,"wind":0.15}
2025-03-23 23:00:34.343 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.19,"licht":35,"regen":1022,"wind":0.15}
2025-03-23 23:00:35.347 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.19,"licht":35,"regen":1022,"wind":0.15}
2025-03-23 23:00:36.350 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.19,"licht":35,"regen":1022,"wind":0.30}
2025-03-23 23:00:37.353 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.25,"licht":35,"regen":1022,"wind":0.15}
2025-03-23 23:00:38.357 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.19,"licht":35,"regen":1023,"wind":0.15}
2025-03-23 23:00:39.360 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.25,"licht":35,"regen":1022,"wind":0.15}
2025-03-23 23:00:40.364 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.25,"licht":35,"regen":1022,"wind":0.15}
2025-03-23 23:00:41.371 DEBUG (MainThread) [homeassistant.components.serial.sensor] Received: {"temp":9.25,"licht":34,"regen":1022,"wind":0.15}
Can someone help me? Or find the problem.
Thank you ![]()
