Question. Can anyone explain to me why in my Dev and Beta Systems the “Configure which network adapters integrations will use” for the addins is available and works fine but for some reason in my Prod system the Option to configure the addins for the nic is missing. I’m also missing allot of other options in my prod system such as being able to “YAML configuration reloading” in it. I’m at a loss as the other two systems are clones of the prod system. The only difference is the Repo that the git addon uses as i test my code before pushing to prod/beta. I’m at a loss because they are essentially the same setup. (Minus the repo and the signin for the cloud.
But is the hardware the same?
Exactly. The Dev and Beta’s are Clones of the original. The only difference is that the prod is signed into the cloud.
Bit of a long shot this - do you have Profile → ‘Advanced Mode’ enabled on the prod system?
