had an automation set up to turns the lights on at sunset and dim at 9- worked fine
I wanted to get the automation to come on earlier - 25mins before sunset, so followed the offset rule.
now its doing nothing,
current code is
description: ""
- platform: sun
event: sunset
offset: " -00:25:00"
- platform: time
at: "21:00:00"
- service: light.turn_on
entity_id: light.sunset_lights_on
brightness_pct: "{{ iif(trigger.platform == 'sun', 100, 50) }}"
transition: 10
mode: single```
the only bit ive changed is the offset bit....
advice?
